Making AUX Input to RB3 Units
Homepage » PEUGEOT MODIFIED PLATFORM » General
08.05.2020 14:13 # 1
IsmailAtes
I am here with such an application since I do not trust the sound of the units that have CD player and not to spoil the originality. In this case, AUX input is visible:) You can remove the tape from the console with 3 mm knitting needles or clothes hanger. The sort of integration we want to hear is the integration of the sound. Soldering the cable of the audio signal that we will give to the legs of the TAPE_R and TAPE_L, which I will give in stereo, from the outside to the left and to the left. We combine and extend it with the help of a cable. Then we insulate the parts we solder with the help of silicone and fix the cables. We cut the red power cable going to the motor on the mechanism and insulate the cable, so when we want to listen to the AUX input, the mechanism will not work and the cable will not wrap around the motor or belt. We connect our audio input cable to any place we want in the tape and prevent the cable from breaking in any undesired movement from outside. We connect the end of the work cable that we have extended in the previous stage to the "+" pole of the capacitor. Solder to a point where it can get chassis in the body. When we do not put the capacitor, we can not get the sound. I wanted to share this project with you because I didn't open it. Because it was not available and I made it with the materials I had, it was like this. It could have been thought more extensively and could have prepared better. We can edit the information on the LCD screen by reading it. When I opened the tape next time, I wanted to state that I want to do such a job. Easy to come.
08.05.2020 14:13 # 2
it looks pretty complicated :)
Thanks bro
08.05.2020 14:13 # 3
mabolla
you said easy come but it doesn't seem easy Gülme
but still health
08.05.2020 14:13 # 4
Ozgur
I will share with you.
08.05.2020 14:13 # 5
MirakGTI
Health for sibling labor.
08.05.2020 14:13 # 6
IsmailAtes
Thank you guys ..
Actually, it is not very complicated but as I said, if you do not have electronic experience, it may sound like that. Gülme
08.05.2020 14:13 # 7
Ozgur
GAYET TELL YOU TELL..BUT I CAN'T Gülme
THAT'S WHAT THE XCARLINK SAYS.
08.05.2020 14:13 # 8
So is it possible to implement this system for rd3?
08.05.2020 14:13 # 9
hasancalp
Hello...
My vehicle is 406 2001 model. As you know, I have a cd changer in my car. I want to input aux to my original confirmation. Which cables should I log in on? Thanks in advance ...
Photos of the cable system http://forum.peugeotturkey.com/forum_posts.asp?TID=5357&PID=156243#156243 at this link.
08.05.2020 14:13 # 10
BAHTIYAR
Thank you for sharing. I also have cassette plugs in the tape, making sizzling fm transmitter pattern room same system.
08.05.2020 14:13 # 11
bayelektronik
My job is not complicated. I think it is perfect. It is a system that does not look more modernized. Alkış
08.05.2020 14:13 # 12
IsmailAtes
Hasan Bey; The application I have made is an application made by giving the audio signal directly on the integrated since the audio input cannot be made from the cables.
08.05.2020 14:13 # 13
Carmania
Your work is good health
08.05.2020 14:13 # 14
hasancalp
[QUOTE = İsmailAte] Hasan Bey is an application made by giving the audio signal directly to the integrated since the application I have made cannot be input from the cables.
Well İsmail bey; Are the circuits in the application that you have made, that is, the integrated legs valid for me. Or are the links different? Also, there is no advantage of having cd changer? I also need to login from tape ...
Thanks sincerely...
08.05.2020 14:13 # 15
oguzhan29
very nice sharing thanks for informing us
08.05.2020 14:13 # 16
[QUOTE = hasancalp] [QUOTE = İsmailA Ateş] Hasan Bey is an application made by giving the audio signal directly to the integrated since the application I made cannot be input from the cables. As far as I know, there is no external input for the sound signal from the output cables of the original tape. [/ QUOTE ]
Thanks sincerely...
I don't know how, but aux can be bought from the cd changer, but I don't know if the cd changer will still work. My changer was already broken Gülme
I don't know how to get it either. I left it to the electrician. After 10 minutes, I connected the mobile phone and started listening to music from the mobile. It seems a little muffled, but I think those who want professional sound enough, they wear their own systems. Anfi tape etc. I wanted at least to control the sound from the remote control of the original. It was. It also works like Cillop.
Arrangement: Tokat / Erbaa was also falcon auto electric. The place I was talking about.
the cover 2010-11-08 01:30:25
08.05.2020 14:13 # 17
IsmailAtes
The probability increases when researched. Of course, the electrician that Murat mentions has done so can not be done, but it is necessary to sit down and work on it. Even with this system, the cd changer can be attached to most of the new cars of the peugeot, so all of them can be given an audio signal over the cd changer line. Because I had the chance to see only the front side of the tape you mentioned a few times, I can not give any definite information since I have never seen the rear cable part or the internal circuit part.
08.05.2020 14:13 # 18
hasancalp
[QUOTE = İsmailAte] When researched, the probability increases, of course. It is necessary to sit down and work on the electrician that Murat mentions, but it is necessary to sit down and work on it. Even with this system, the cd changer can be attached to most new vehicles of the peugeot, so they can all be sounded over the cd changer line. As I said, it is a work that needs to be worked on because I had a chance to see only the front side of the tape you mentioned, I cannot give any precise information since I have never seen the rear cable part or the internal circuit part. [/ QUOTE]
İsmail Bey; If you want to help me, I can show you all the contact pictures and internal pictures of the confirmation ...
08.05.2020 14:13 # 19
Haksen016
As you said, it is a very skillful job :) If I personally try to do it myself, I have to buy a new tape after all.
08.05.2020 14:13 # 20
hasancalp
Nobody here helped. But thanks to God, I took care of the aux ... I will post it here with a photo ...
Page : / 2
