maintenance price
08.05.2020 18:38 # 1
206x-line
friends, I say I have a complete maintenance for my vehicle, for example, there were ten sets of oil, it was the filter, the engine ear wedge, the timing set, the gas pump. 206x-line 2014-06-21 23:00:49
08.05.2020 18:38 # 2
samet206
I recently had a filter maintenance, oil-oil filter-pollen-air-spark plug-engine additive-fuel additive-throat throttle cleaning, including a total of 300 TL. If you find TL, it keeps a figure like 900 TL in total, if all of them are improved together, if the workmanship is improved, I guess again, the amount of 700 - 800 is what you said.
08.05.2020 18:38 # 3
droprain72
In which part of Istanbul are you close to Kartal, there is a very good master that I can recommend to you?
respects...
08.05.2020 18:38 # 4
asbircan
Kartal, where you can recommend this master, there is a problem in my vehicle, I could not solve it for 2 years. Thank you.
08.05.2020 18:38 # 5
droprain72
my friend
There is a team auto in the eagle industrial style. Şenol master. I have been a pejo user for about 8 years and I always take my cars to him. He is a competent master of his job. When the Eagle industry enters from the lower main road, it is 50 meters to the right and the team auto on the right.
08.05.2020 18:38 # 6
206x-line
I'm by Bahçelievler
08.05.2020 18:38 # 7
asbircan
[QUOTE = droprain72] my first friend
I know, yes, I heard the Şenol master. the asbirc 2014-06-24 11:18:21
08.05.2020 18:38 # 8
tetik-soner
If you are going to take care of it, get ready in 1000-1500 TL pocket.
08.05.2020 18:38 # 9
okan77
[QUOTE = asbircan] [QUOTE = droprain72] my asbircan friend
I know, yes, I heard the Şenol master, would he be interested? [/ QUOTE]
I was there at the weekend, timing oil change, engine ear plugs, maintenance oil change, pad change etc ...... You can have a little installment by giving some cash ... What is the problem that has not been solved for 2 years ...
08.05.2020 18:38 # 10
asbircan
[QUOTE = okan77] [QUOTE = asbircan] [QUOTE = droprain72] my asbircan friend
Master, the link I opened when I first met: http: //forum.peugeotturkey.com/forum_posts.asp? TID = 23949 & title = transfer-interest-problem
links after having it done at intervals afterwards: http: //forum.peugeotturkey.com/forum_posts.asp? TID = 27803 & KW = asbircan & title = gas-not-eating-idle-irregularity-exhaust-explosion
If the message from the links is problematic, let me paste it briefly.
Even when idling, the idling engine keeps vibrating between 800 rpm and 1200 rpm and the vehicle stops if I press the earthquake and gas during the wobble process.
1- I changed idling engine (original 153TL)
2-throttle and throat cleaned 30TL
3- again connected to the device 20TL
4- valve settings made 50TL
5-spark plugs changed 30TL
6-complete maintenance was done + clutch set changed.
7-adaptation was performed.
8-timing belt change was made again, the adjustment was removed.
etc
and they said they could be from the last folder
08.05.2020 18:38 # 11
asbircan
[QUOTE = 206x-line] friends I say I have a complete maintenance to my vehicle, for example, it was ten sets of oil was its filter, engine ear pad timing set gas pump, so how much would it cost if there was a maintenance, or did you have a good master in Istanbul [/ QUOTE]
Let me write the expenses I made to give you an idea.
Oil Filter: 13 orj.
Air filter: 27 origins
Fuel filter: 14 orj
Pollen filter: 25 origins
spark plugs replaced 40 equivalent
Click the back bata.:143 org.
Rear brake center: 35 mirrors ((orj: 103tl))
Fuel pump: 260 mirrors ((original: 460 and 100 are made in china))
Right_Sol rod head: 55 equivalents
Rod handle: 35 equivalent
Right_Sol pad: 35 org.
Printing pad set: 319 origins
75 motor or top
lower engine lug 60 orj
front pad kit 40 equivalent
repair of caliper sets 60 TL
Transmission oil: 60
It takes 180 TL 3-4 hours as workmanship, if all parts are ready.
08.05.2020 18:38 # 12
206x-line
Where did you get asbircan
08.05.2020 18:38 # 13
asbircan
[QUOTE = 206x-line]
Where did you get asbircan [/ QUOTE]
I bought the parts from the coachman and can automotive, I made the work in s-car volvo special service in walnut
I found the middle way by adding a little bit to the engine oil, I gave 120TL to the oil :-)) the asbirc 2014-06-24 23:34:55
