Maintenance Period
08.05.2020 18:23 # 1
ooozzziii
I have 206 people and it is ten thousand km since I bought the vehicle. I changed the oil on the day I bought the car. When should I change the oil again? And in what interval should the power steering oils of these vehicles be renewed? One last question, do I have to change my car's air filters now? Thanks in advance :)
08.05.2020 18:23 # 2
kivanc
[QUOTE = ooozzziii] I have 206 owners and it is ten thousand km since I bought the vehicle. I changed the oil on the day I bought the car. When should I change the oil again? And in what interval should the power steering oils of these vehicles be renewed? One last question, do I have to change my car's air filters now? Thanks in advance:) [/ QUOTE]
I used 206 hdi for a long time. I was replacing the oil in 10 thousand, oil air pollen filter.
08.05.2020 18:23 # 3
kaf kef
already standard 10 thousand maintenance yag air diesel pollen filter change I do not know the hydrodrection
08.05.2020 18:23 # 4
ahmed206
In the program in me, the 2007 maintenance intervals appear to be 15000 km.
What is the car?
08.05.2020 18:23 # 5
ahmed206
Also to turn off the service light:
Turn the ignition off
Press and hold the right button on the instrument panel
Meanwhile turn on the ignition (without starting)
Hold the button for 10 seconds
08.05.2020 18:23 # 6
ooozzziii
The car was now at 86 thousand when I bought it.
08.05.2020 18:23 # 7
ahmed206
Replace engine oil, filter, air filter, diesel filter, pollen filter at 90 thousand, adjust hand brake, clean battery heads and renew brake fluid in case it has not changed so far Thumbs Up
08.05.2020 18:23 # 8
ooozzziii
Thanks for your comments, especially I take note of the ones listed in the last comment :) do you think I should have this care done in the service or on my own master?
08.05.2020 18:23 # 9
jack67
Oil 5W40 75TL
Oil filter 10 TL
Air filter 15 TL
Pollen filter 15 TL
Diesel filter 50 TL
Dot4 brake fluid 500ML 15 TL x2
Outside prices, such as a total amount of 195-200, they do 50 max lira in labor. In the service, the materials take at least 100-150 as 250-300 amount of labor.
08.05.2020 18:23 # 10
ahmed206
Take the materials yourself and say that they will change. If there is no master to trust, go to the service but I don't know if the service will accept it this way.
08.05.2020 18:23 # 11
ooozzziii
We can close 200 to 250 then this maintenance event. After a little research, I gave up the service and I think a good master will do our job.
08.05.2020 18:23 # 12
herry
I do not know how many thousand of your vehicles change to 90 thousand, but they are replacing the timing of apricot change in 90 thousand in gasoline 206. it's important to keep that in mind.
08.05.2020 18:23 # 13
ooozzziii
I asked the trigel belt for peugeot service, they said it will change in 125 thousand.
08.05.2020 18:23 # 14
herry
Then there is a lot more
08.05.2020 18:23 # 15
ahmed206
I asked the [QUOTE = ooozzziii] trigel belt to peugeot service, they said it will change in 125 thousand. [/ QUOTE]
In my service manual, the timing period appears to be 100,000 km. Replace if it hasn't changed before
