maintenance mileage falls faster than normal |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 21:04 | # 1 |
My 2006 model partner vehicle maintenance mileage every time I open a contact 100 minus, meanwhile, up to 20 kilometers per day. I'm on the way. But a footnote like this: when I was about to start my car the other day He was interrupted. I opened the hood, and one of the heads was loose, I put it in place And I squeezed electricity came, the car worked. Date time auto lock set another there was no problem. Why is the maintenance mileage falling outside of normal? I would appreciate if friends with knowledge on the subject help.
| 08.05.2020 21:04 | # 2 |
HasGur |
[QUOTE = gregor samsa] hello My 2006 model partner vehicle maintenance mileage every time I open a contact 100 minus, meanwhile, up to 20 kilometers per day. I'm on the way. But a footnote like this: when I was about to start my car the other day He was interrupted. I opened the hood, and one of the heads was loose, I put it in place And I squeezed electricity came, the car worked. Date time auto lock set another there was no problem. Why is the maintenance mileage falling outside of normal? I would appreciate if friends with knowledge on the subject help. [/ QUOTE] For example, if 15,000 KM or 1 YEAR is planned for periodic maintenance of your vehicle; Periodic maintenance mileage and duration are tracked separately by the vehicle software. If the maintenance mileage will expire before 15 thousand km, the actual km remaining is deducted from the remaining km, but if the 1-year period will expire before km, much more than the distance traveled, so that the maintenance mileage can be shown as zero. Since you do not travel long, 15 thousand km will not be filled, but maintenance will be done due to the 1 year period. |
| 08.05.2020 21:04 | # 3 |
Planned maintenance is 10000 km (there are 4900 km) There are 4 4.5 months to a year.
| 02.10.2020 20:33 | # 4 |
Did you find a solution to the problem of rapid decrease in service maintenance counter? I have the same problem with my 2003 model 206 vehicle.
