Maintenance Light Burned Early
08.05.2020 20:36 # 1
hermanito
Hello 900km ago, the vehicle was serviced, maintenance service key had not appeared yet. After the maintenance, we set the key to 0, 20.000 km. Now 19100, the service key appeared for maintenance. Does it have a burning condition or is there something that needs maintenance?
08.05.2020 20:36 # 2
my teacher probably could have another malfunction. I say reset and try again. is the light on again?
08.05.2020 20:36 # 3
hermanito
I reset it is still lit because it is the only column screen that doesn't write the reason on the vehicle information screen?
08.05.2020 20:36 # 4
No malfunction code can not see from there, there is probably another problem needs to connect the pc. If you are on the side of etimesgut - sincan - eryaman, i can also have an obd device for free.
08.05.2020 20:36 # 5
hermanito
I am close to my teacher, when I am available, where do I come?
08.05.2020 20:36 # 6
[QUOTE = hermanito] When my close friend is available, where will I come? [/ QUOTE]
I will be available like 9 pm. you can reach it on your mobile. 0505 789 36 33 If I do not have a job, I would appreciate if you call before coming. we can meet in wonderland.
08.05.2020 20:36 # 7
hermanito
OK, I saved the number, I will call you in the evening, if something goes wrong
08.05.2020 20:36 # 8
[QUOTE = hermanito] OK teacher I saved the number, I call in the evening if nothing goes wrong [/ QUOTE]
Wait, teacher, send a message and I will save it. Thumbs Up
08.05.2020 20:36 # 9
uzunca961
[QUOTE = sonerkyl] [QUOTE = hermanito] When my close friend is available, where will I come? [/ QUOTE]
I wondered where the wonderland was, Soner teacher :)
When you reset the joke aside, do you see it on the screen, hodja?
There is no such thing as I set it to 20000 as I know it. I think there is a possibility that it was not reset before 900. it seemed burned when you finished 900 because you couldn't reset it
08.05.2020 20:36 # 10
hermanito
When I say I set it to 20.000, it automatically adjusts itself.
08.05.2020 20:36 # 11
uzunca961
Well, this is the first time I heard that I was not interesting to reset my teacher.
08.05.2020 20:36 # 12
KILIC
[QUOTE = Uzunca961] Well, this is the first time I heard something like an interesting teacher reset [/ QUOTE]
I do not mean resetting do not make the remaining 20 thousand km for maintenance.
08.05.2020 20:36 # 13
uzunca961
[QUOTE = KILIÇ] [QUOTE = Uzunca961] Well, this is the first time I heard of not resetting my interesting teacher [/ QUOTE]
I know it was so, teacher, I did it.
08.05.2020 20:36 # 14
maximusti
I know that it keeps maintenance time (like 12 months) except for km but I am not sure.
08.05.2020 20:36 # 15
hermanito
Soner met with my teacher, he just took the time, thanks for me. Extra key opener was not working Soner teacher took care of the problem.
08.05.2020 20:36 # 16
[QUOTE = hermanito] Soner met with my teacher, just let's take the time. Extra key opener was not working. Soner, my teacher took care of it. Thank you. [/ QUOTE]
you are welcome murat brother Meanwhile, I'm glad to meet you.
