maintenance information does not reset
09.03.2023 23:15 # 1
hfk8
I have a 2010 model peugeot 308 1.6 hdi. There was a headlight failure in my vehicle, we wanted to fix one of the fuses by removing and replacing it, we unknowingly removed the yellow fuse with the lowest amperage of 5 and inserted it, and suddenly the repair key sign, which is the maintenance lamp, came on even though the vehicle took longer to maintain, I reset it by counting down, but it lights up again. I reset it 5 minutes later the lamp is on again. The battery ran out, I had to make a boost, when I reset it after the boost, the lamp went out. It didn't light for 1-2 days, then I bought a new battery, but this lamp came on again. When I reset the maintenance information, the mileage appears to decrease continuously and after a while the lamp turns on again. I have searched a lot on the forum and other sites, but I have not come across anyone in a similar situation.
22.08.2024 22:20 # 2
burakdag
Hello, I am having the same problem, I reset it but it immediately turns on, did you find a solution?
