Maintenance cost |
| 08.05.2020 16:34 | # 1 |
* the current gearbox oil is troubled especially when shifting to 1st and 2nd gear, especially when shifting to reverse gear If I don't remove my foot from the clutch, it won't pass * Km. I guess the needle will have jumped, it doesn't show its true course, while I travel with 50, I will move with the pointer at 10 o'clock * 3 cm and 30 cm inward as a result of rubbing romorka at the front headlight and glass level. length left pit * the left rear door lock will be faulty, but we can open it from the inside, the door is not opened from the outside If I do not pull it up, it does not hold, I want to have the brakes put on the pads. * There is a break in the left tail lamp, I need to replace it with the original & nbsp; I would be pleased whatever the average cost of the peugeot service I wrote at 90,000 km and above. & nbsp; & nbsp;
| 08.05.2020 16:34 | # 2 |
no answer guys |
| 08.05.2020 16:34 | # 3 |
Those who use 206 will help you. |
