maintenance
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
08.05.2020 18:27 # 1
aksoy06
Greetings to everyone, Peugeot 307 1.6 XT 2002 my baby gazelle, I just bought it was gasoline, I bought lpg, I ordered oil boron and engine oil cleaner from the internet, I also take care when I get ready, what do I buy? Oil filter, air filter, fuel filter, pollen filter, what comes to my mind, what is the estimate and what else do I buy, I would appreciate it if you help ....
08.05.2020 18:27 # 2
tetik-soner
I think using additives ...
08.05.2020 18:27 # 3
aksoy06
[QUOTE = 307bursa] If you just bought the car, it is useful to have the timing set and the linings checked and replaced [/ QUOTE] I will have trouble with the timing but I show the pads, thank you.
08.05.2020 18:27 # 4
ahmet_bjk
[QUOTE = trigger-soner] I think using additives ... [/ QUOTE]
+1
08.05.2020 18:27 # 5
ahmed206
Why don't you recommend additives?
Here, a master said, let's pour boron additive injector cleaners to the warehouse.
08.05.2020 18:27 # 6
aksoy06
I don't use [QUOTE = trigger-soner] additive ... [/ QUOTE] why don't you recommend it? By the way, do not you recommend boron or engine oil cleaning agent? because engine oil is used for cleaning oil change.
08.05.2020 18:27 # 7
aksoy06
[QUOTE = ahmed206] Why don't you recommend additives?
Sir, I think you should use a syringe cleaner, use some pipes, but someone who uses a syringe cleaner has always stuck with the injector that stuck out of that substance. I was going to use it, I gave up. They say good for oil cleaning agent if you are going to change engine oil. you were running 15 minutes before changing it, then you opened it from the bottom and drained all the dirt and run the new oil. investigate.
08.05.2020 18:27 # 8
suppor
I kept 850 TL, 50 workmanship 900, but it was done.
08.05.2020 18:27 # 9
aksoy06
[QUOTE = suppor] I kept 850 TL, 50 workmanship 900 but it was done quite a bit when I got the list of the parts that changed from the master [/ QUOTE]
Hodja, thank you very much, I would be glad if you share the list.
