MAINTENANCE
08.05.2020 20:56 # 1
hulya1558
Friends, I will have one more question, what has been the maintenance, what are they looking for in the care?
08.05.2020 20:56 # 2
For general maintenance, it is enough to change the following if there is no extra situation in the vehicle.
1-air filter
2-pollen filter
3-oil filter
I recommend 4-engine oil 10w / 40 mobil or motul brand.
08.05.2020 20:56 # 3
hulya1558
thanks, how much does it cost up and down?
08.05.2020 20:56 # 4
With 200 TL amount of workmanship.
08.05.2020 20:56 # 5
uzunca961
If the price of maintenance is high, you can call the industry or master, workmanship, how many would you like to buy the pieces
08.05.2020 20:56 # 6
hulya1558
thank you guys.)
08.05.2020 20:56 # 7
HasGur
[QUOTE = sonerkyl] max 200 TL with labor.
With the oil in the link, I bought the original diesel, oil, air filter and domestic pollen filter for the 1.6 HDI and the turbo seal +10 rocker seal clips 220 lira 3 days ago from the industry. 195 TL when the gaskets and clips are released. The price difference between the petrol 206 and the diesel 307 filter set is very small in this case.
08.05.2020 20:56 # 8
uzunca961
If there is no one you know, there is Pax auto in ikitelli industry, at least they won't cause any problems for maintenance.
I call ahead and get a price, but maybe they raised the price
[QUOTE = hulya1558] thank you guys.) [/ QUOTE]
08.05.2020 20:56 # 9
[QUOTE = HasGur] [QUOTE = sonerkyl] max 200 TL with labor.
It is true, teacher, I add links in order to be an example. As we know, the prices on the internet are always high, of course, compared to the metropolitan areas. I went to maintenance in the holiday archive and I made maintenance for my 1.6 vti vehicle.
1-front disc delphi (150 tl)
2-front and back pads 4u (90 TL)
3-air-oil filter original - pollen sub-industry (30 TL)
4-motul 5w-30 fe engine oil (105 tl) 4 liters
5-one bolt (gift)
I gave 375 TL to the materials. Worked 100 TL. I called the lathe to thread the bolt socket, a place was open, it took 40 TL. It took a little too much to do. Smile
08.05.2020 20:56 # 10
HasGur
[QUOTE = sonerkyl]
I guess ennn originals like me are the primary product pollen filter preferred by the supplier industry. Big smile
08.05.2020 20:56 # 11
[QUOTE = is Hasgör] [QUOTE = sonerkyl]
That's it, teacher, actually, there are sub-industry carbon pollen filters. usually not much Big smile keep on white
08.05.2020 20:56 # 12
hulya1558
friends km maintenance master 270 tl + 50 tl rot balance adjustment said normal do you think?
He said there is no problem turning on the fan in fever!
08.05.2020 20:56 # 13
Maze87
[QUOTE = hulya1558] friends said rot balance adjustment at 270 tl + 50 tl, km maintenance do you think is normal?
Rot balance is expensive, I make 25 TL for your island
08.05.2020 20:56 # 14
hulya1558
brother here is istanbul :)
08.05.2020 20:56 # 15
HasGur
[QUOTE = hulya1558] brother here istanbul:) [/ QUOTE]
Cheap city istanbul Smile 50 TL for 4 wheel balance + rod adjustment is a very low price.
According to the profession room price tariff, the front tie rod adjustment is 26 TL for the rear vehicle, 20 TL for the rear and 28 TL for the four-wheel hair rim and 36 TL for the steel rim.
Industrial trades do not work at the bottom list price ... If the rot setting is not played with the front set, it will not be disrupted, make sure the rot setting is done! If adjustment is not required, they will not receive money anyway.
