maintenance.
08.05.2020 17:12 # 1
peugeotttt
friends, I will be servicing my car, it explodes.
& nbsp;
& nbsp;
swings
& nbsp;
dampers >
& nbsp;
tie rod ends
& nbsp;
brake oil hoses
& nbsp;
4 tires
& nbsp;
front brake pads
rear brake discs
& nbsp;
of course, oil care has come, and it will be done.
& nbsp;
what I think of now will go into more detail when they go to the master. / div>
& nbsp;
& nbsp;
08.05.2020 17:12 # 2
peugeotttt
None of them were needed, I went to the master, I looked down from the beginning today, the car also needs to be replaced, just the front brake hose and steering hoses.
& nbsp;
the cost of 70 lira :))
& nbsp;
my lion made me happy this day :)
08.05.2020 17:12 # 3
peugeotttt
and I also bought 4 tires for the lion today 700 lira.
& nbsp;
I changed the antifreeze filter for 80 lira.
& nbsp;
home my car was flying with happiness when it came :) :))
08.05.2020 17:12 # 4
MagicPerformance
206 gti of vehicle, oil filter and antifreeze 70 tl? no mistake?
08.05.2020 17:12 # 5
peugeotttt
Antifirize did not receive any money anyway.
08.05.2020 17:12 # 6
baris
is it healthy to put full antifreeze in the vehicle?
08.05.2020 17:12 # 7
peugeotttt
I don't know how much.
08.05.2020 17:12 # 8
baris
In my mind, where 206 pollen filter is on the vehicle?
08.05.2020 17:12 # 9
peugeotttt
When you open the bonnet, the right shock absorber stays just under the glass, there is a gap, and you see there.
08.05.2020 17:12 # 10
baris
Thank you bro!
08.05.2020 17:12 # 11
peugeotttt
"Wink"
08.05.2020 17:12 # 12
Barut
I'm glad on behalf of you lion thinks it doesn't cost you much
08.05.2020 17:12 # 13
hsnsnl
[QUOTE = peace] Is it healthy to put full antifreeze on the vehicle? i would recommend you to use color antifreeze .. i am in izmir and i put 1lt enough :)
08.05.2020 17:12 # 14
peugeotttt
[QUOTE = 206xs] glad for you, lion thinks it doesn't cost you much [/ QUOTE]
yes it doesn't upset I wish it was always like this :) but before anything, of course it is to do maintenance on time.
08.05.2020 17:12 # 15
_pathfinder_
Pure antifreeze is not put into the vehicle, my master, the antifreeze feature is combined with the water added to the antifreeze. The pure antifreeze does not work at all.
08.05.2020 17:12 # 16
tellotello
Pure antifreeze can be placed without any problems, the only problem is pure antifreeze -protection up to -12. However, 50 percent antifreeze and 50 percent water mixture provides protection down to -37 degrees and the liquid circulating in the engine does not freeze up to these temperatures. If the temperature can be guaranteed not to drop below -10, it can be set & nbsp; "Smile".
08.05.2020 17:12 # 17
outlaw
I have never heard of pure antifreeze put in half and it will be mixed, then the freezing point will be better.
08.05.2020 17:12 # 18
tellotello
Whether or not the situation will be set & nbsp; "Smile", if desired, there is a gap between the freezing point of pure antifreeze and the freezing point of the mixture in half. I wanted to mention it. There is not much advantage of just putting antifreeze; It is more advantageous to put a mixture. & nbsp;
