lutfn help
08.05.2020 19:05 # 1
trabzonlu207
I have 207 vehicles in 2008 model. shifts out of the car while driving ??? What is the reason . especially the first gear
08.05.2020 19:05 # 2
monalos
Are you throwing away touching your sister, while cruising or on the first departure
08.05.2020 19:05 # 3
monalos
I did not try to get your sister up the car in 2nd gear, if the car is leaving, clutch pressure is solid and I think it may be a problem with the gearbox.
08.05.2020 19:05 # 4
trabzonlu207
No problem on departures.
Also in my printing pad. i am sure of that. .Car started to deviate ..
Stupid voices are making sounds .. The cycle is rising at once. car shouts shakes
08.05.2020 19:05 # 5
Barut
Does this problem happen in 1st, 3rd, 5th gears?
08.05.2020 19:05 # 6
monalos
My brother knows better, my sister I do not know much mechanics
08.05.2020 19:05 # 7
sezar206
I don't think it's from pressure. Have a look at the gearbox or gearshift levers. I think most likely die from the rope. He is unable to fully fit and shifts out of him.
08.05.2020 19:05 # 8
T€K€
Transmission synchromesh malfunction
08.05.2020 19:05 # 9
trabzonlu207
Now I drive.
The tire was getting cold, I was blowing them
There was a creaking noise coming from the car (with the gear in neutral). (engine hot)
08.05.2020 19:05 # 10
SDYMZ
Does the gear shift happen in every gear? synchromesh caused by gears
08.05.2020 19:05 # 11
Efe-Pojo
synchromesh malfunction. The track is a simple thing, but the gearbox's downtime is a laborious and crafting event. I think it is not worth trying if there is no throw in other gears, because when I understand your character, I think you can control this throwing job yourself. I don't think he will throw it away if he is used calmly.
08.05.2020 19:05 # 12
trabzonlu207
Thank you very much
He's overwhelmed me recently, my lion ..
08.05.2020 19:05 # 13
monalos
Sister would be sick or sick, after all, a room can :)
