Lung Supplement to the Machine (34db1416)
08.05.2020 19:13 # 1
KuzuX
I bought a 206 filter kit and entered 5 more paints. Smile I strongly recommend it for those who consider taking it. There was a big change in the way the vehicle went, the acceleration of the traction was more aggressive. I calculated the fuel immediately after buying it, believe it, there was no difference in fuel. Whatever burned it before, the vehicle burned the same. There was a lot of talk because it would burn but there was no difference. The sound is quite satisfying already, the sound gets aggressive after 3 thousand cycles. After inserting the car into the cutter, the sound is pretty remarkable. Anyway, I strongly recommend friends .. Thumbs Up
08.05.2020 19:13 # 2
herry
good bro
You have plugged the oil mist drain hose into the wrong hole. it had to get into the hole on the filter kit, if that hole is going to be open, I recommend you close it, the dust will get dirty.
08.05.2020 19:13 # 3
KuzuX
The drain hose does not enter that hole, is there an additional part of the master?
08.05.2020 19:13 # 4
herry
it should normally enter, perhaps a little modification may be required. This is not a problem, but close the hole with a diaper band that is open.
08.05.2020 19:13 # 5
koray.turan
What is going on in this market?
08.05.2020 19:13 # 6
koray.turan
Good luck by the way
08.05.2020 19:13 # 7
KuzuX
[QUOTE = herry] should normally enter, perhaps a little modification may be required. This is not a problem, but close the hole with a diaper band that is open.
It is necessary to cut it a little bit. Actually, if I cut the part of the original kit into the throat and fit it, I don't want to spoil it. At the first opportunity I would close that hole, I had the hair, but the biker remained when he said nothing would happen.
@ koray.turan
It is called as 206 Performance Filter Kit. Thank you. You pay 180 TL, but you really feel the performance. Frankly, I wasn't expecting this much performance increase.
kuzux 2015-04-11 22:14:52
08.05.2020 19:13 # 8
koray.turan
Thank you very much.
08.05.2020 19:13 # 9
KuzuX
[QUOTE = koray.turan] Thank you, this is what I am looking for, be good again [/ QUOTE]
You're welcome.
08.05.2020 19:13 # 10
kopiiilcan
This is exactly what I was looking for. How much did you get, buddy? But there are many prices on the Internet.
08.05.2020 19:13 # 11
GokhaN
good luck you see some fuel Smile wake up your car has not waken up, then you will see exactly how much oxygen you use as much fuel as it will increase, then it will not be the same if you return to the original. This traction is due to the load on the gas so that I can hear a little bit of sound in the increases.
08.05.2020 19:13 # 12
herry
Exactly
08.05.2020 19:13 # 13
tetik-soner
best wishes....
08.05.2020 19:13 # 14
outlaw
[QUOTE = GökhaN] good luck you see some fuel Smile wake up your car has not waken up, then you will see exactly how much oxygen you use as much fuel as it will increase, then it will not be the same if you return to the original. This traction is due to the load on the gas so that I can hear a little bit of noise in the increases [/ QUOTE]
FROM THE SAME WINNER FILTER, I HAVE ALSO LIKE AS YOU SAID, HOW OXYGEN INCREASES PERFORMANCE INCREASES, BUT INCREASES IN THE FUEL ..
08.05.2020 19:13 # 15
KuzuX
I have been using it for about 2 months and there is no change in fuel. I disagree with the event that you call. Let me know what the vehicle is buying.
08.05.2020 19:13 # 16
Efe-Pojo
enjoy it. Is the same sold for 207?
08.05.2020 19:13 # 17
samet206
It is nice to use it on good days. I think it is better to take the kit like this by removing the box and attaching an open air filter to the end of the plastic pipe, it will be better to use the metal pipe because it is metal and it will be better to use the metal pipe in this case. There is a more logical kit that delays contamination and adds visual to the work. It is true if the kit is of good quality and designed well, and if it is installed correctly by the user, this is what I said. I coincided with what happened to me. I used an open air filter, I didn't feel anything in fuel, but I returned to the original because I couldn't get the sound I wanted shortly after.
08.05.2020 19:13 # 18
KuzuX
There is no problem so far. It only screams at high speeds of 150 to 160. It may be necessary to disassemble on a long journey. But it's ideal for daily use. Occasionally I put it in the cutter, the neck breaks :)
