Luggage shock absorber replacement
08.05.2020 21:23 # 1
izgkhan
slm friends If I am going to talk about a few issues, if your luggage shock absorbers are broken, buy a new sub-industry shock absorber and this shock absorber is 330 niftons so write 330N on it, but do not buy it directly because the heads that fit the boot are throwing them out, they do not fit completely, so remove the plug-in heads of the original luggage dampers. it is not fixed, you can turn it right and turn it to the left) and attach it to the luggage dampers you just bought, you will not have any problems. Also, you don't think you should take the nifton high, it will blow up the tailgate.
08.05.2020 21:23 # 2
OguzzKann
[QUOTE = izgkhan] slm friends If I am going to talk about a few issues, if your luggage shock absorbers are broken, buy a new sub-industry amateur and this shock absorber should be 330 niftons so write 330N on it but do not buy it directly because the heads that fit into the trunk will be displaced, it does not fit completely, for this reason, the original luggage dampers do not fit. take off their heads (they are screwed, they are not fixed, turn them out by turning them to the right and left) and attach them to the newly purchased luggage dampers, you will have no problems. Also, don't assume you don't take the nifton high, it will blow up the tailgate [/ QUOTE]
Where and how many shock absorbers did you get on the mainland?
08.05.2020 21:23 # 3
izgkhan
I bought the baggage shock absorbers changed and until I resolved the nifton event.
08.05.2020 21:23 # 4
izgkhan
I bought the baggage shock absorbers have changed and until I resolved the nifton event.
08.05.2020 21:23 # 5
Yes, your amotisor heads can sometimes be a nuisance. Thanks to the supplier industry for information.
