Luggage remained locked. (206) ..
08.05.2020 19:09 # 1
koray.turan
Everyone has a good evening .. My car's luggage has not been opened for some time, was locked. I searched but I did not get the necessary answers. I just downloaded the back seat and dipped into the trunk :) but I couldn't understand, could someone with the knowledge give me information how can I open the trunk my car 206 by the way pleasant forums the koray.tur 2015-03-13 22:02:05
08.05.2020 19:09 # 2
koray.turan
Lock engine is broken, by the way, friends. I was making a subtle sound and the doors were not locked.
08.05.2020 19:09 # 3
koray.turan
Upppp
08.05.2020 19:09 # 4
xmen
If you can reach the lock from the inside, there must be a small hole, then press it with a thin screwdriver, it has to be opened in this way, as far as I know ...
08.05.2020 19:09 # 5
talip206
The lock engine is probably not faulty. Since there is a problem in the tailgate, it does not lock the other doors. When one of the doors is open, the doors are not locked from the control
08.05.2020 19:09 # 6
koray.turan
[QUOTE = xmen] if you can reach the lock from the inside, there should be a small hole, press it with a thin screwdriver, it should open like that, as far as I know ... [/ QUOTE]
I'll try tomorrow and let's thank you
08.05.2020 19:10 # 7
koray.turan
[QUOTE = talip206] Your lock motor is probably not faulty. Since there is a problem in the tailgate, it does not lock the other doors. When one of the doors is open, the doors are not locked from the control [/ QUOTE]
When I press the kbagaj from the lock, the sound of the scraping sounds.
