lubricated on left wheel and left fender (solved)
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 508
08.05.2020 16:08 # 1
AliOzagan
friends, I realized that there was lubrication on the left side of the vehicle and on the fender side, I realized that it was a little late. "smileys / smiley5.gif" border = "0" alt = "C o nfused" title = "C o nfused" />
axle bellows torn and grease with grease flowing inside Thanks to those who helped me in this process, it has disappeared in this way because it did not harm the axle gears since it did not run out of oil.
AliÖzagan 2011-09-19 12:11:55
08.05.2020 16:08 # 2
mon
the axle bellows is split, that is the black rubber material there. Is it sold separately? you have to ask him. otherwise you may need to replace the axle completely.
08.05.2020 16:08 # 3
metin
The axles are missing from the seals, change the seals and make the oil drop. that oil is gearbox oil.
08.05.2020 16:08 # 4
AliOzagan
So I have to do it urgently and what is the cost to me? Is it okay :( AliÖzagan 2011-09-18 22:26:29
08.05.2020 16:08 # 5
metin
[QUOTE = AliÖzagan] so I have to make it urgent and what is the cost to me and what effect do you think the vehicle will have on automatic transmission oil, etc. Is it okay? If you are interested in ready-made gearbox oil, change the oil if the oil has not changed before.They normally say it will last a lifetime, but an oil should be changed at 30,000 km.
08.05.2020 16:08 # 6
metin
use original parts sponsor hawk peugeot murat don't buy parts from brother. Some of them sell the sub-industry because they are original, note that the original parts are sold in the original box.
08.05.2020 16:08 # 7
as far as I can see, the left & nbsp; outer axle seal is missing. It is a flow integrated with the internal axle connected to the gearbox. It is not sold as a left axle alone. He jumped all over with speed. & nbsp;
You asked if I should have an emergency. When you completely drain the oil in time, the balls attached to the wheel are dispersed. Once you turn the steering wheel, you can not pick up again "Blink" & nbsp The car stays where it is. The price of
is not less than 160 TL. Also, 30-40 TL gearbox oil costs you around 200.
08.05.2020 16:08 # 8
AliOzagan
Thanks for the answers, I made a long road between Antalya and Antalya at the end of the feast.
