lpgli consumes a lot of gasoline
08.05.2020 15:07 # 1
buruker
hello friends car 307 lpgli
I know the problem of the indicator.When the car is going to LPG, the petrol needle falls, but it is said that the petrol does not decrease.
last week I bought 85tl lpg 65 tl gasoline. Normally the gas light was on and the half tank was one notch. I traveled 320 km with these tanks. I bought another 20 TL gasoline.
When the gas was gone, the gas light was also lit. I bought gas of 90 TL. At 30 TL, petrol came to the half-tank line.
I burned 85 tl gas and at least 50 tl gasoline at 320 km:) I would be glad if there is any information or solution.
08.05.2020 15:07 # 2
klemann
It shouldn't burn. The vehicle is passing over to the LPG. Also, the weather is cold, the first time it burns, but it does not. I think there is a problem with the indicators. my c3 does the same. Don't believe the indicator.
08.05.2020 15:07 # 3
buruker
I can not say that it was too late, maybe in the morning, but it is almost 100 m later in the day.
08.05.2020 15:07 # 4
dukenukem82
Use indicator resetting maybe you think it's falling like other LPG pejoes. I don't know your full name, but it was something like that
08.05.2020 15:07 # 5
buruker
how do i reset
08.05.2020 15:07 # 6
sercinho
Each time the psa module called by the friend starts the vehicle, it detects the vehicle as if it has received gasoline and updates the condition of the gas in the tank, and they wear it in the services or lpg conversion places.
08.05.2020 15:07 # 7
buruker
I heard that the module is harmful. It disrupts the gas pump and causes serious expense.
08.05.2020 15:07 # 8
sercinho
I appreciate it in the service, I don't know if it is something, I don't know who I do not know, but I don't know you, but the LPG conversion is at the service. There are friends, I have not seen a problem, I have heard that if you use the gas pump under the quarry tank, there is a deterioration, I heard that the room is doing the cooling of the pump with the gas inside it.
08.05.2020 15:07 # 9
buruker
THANK YOU FOR THE INFORMATION YOU GIVE
08.05.2020 15:07 # 10
BAHTIYAR
There is a problem in your car, I put 25 pounds of gas a month, we use the vehicle every day, 400km 25 pounds of gas is on average, it goes to 36c in lg carburetor vehicles are called breakers.
08.05.2020 15:07 # 11
sfyucedag
When you start the car in the morning, you may use LPG in gasoline until you go straight to LPG without waiting.
08.05.2020 15:07 # 12
metin
Have you made the km agenda for 1 month? As friends say, if you are going in the morning in gasoline, I say it is normal for 1 month to burn so much gasoline.
I speak again according to 1 month. If the engine is running late, you should look at the thermostat.
For example, my vehicle was switching to gas at 8 km but we looked at the thermostat faulty, now it is switching to the gas within 500 meters in the cold engine. this reduces gas consumption.
08.05.2020 15:07 # 13
buruker
[QUOTE = text]
For example, my vehicle was switching to gas at 8 km but we looked at the thermostat faulty, now it is switching to the gas within 500 meters in the cold engine. this reduces gas consumption. [/ QUOTE]
I did it in 1 month. Actually, I don't go too much on gas. When the engine is cold, it passes at 100m when the engine is cold. The last 90tl gas was bought 30tl gas.
08.05.2020 15:07 # 14
BAHTIYAR
[QUOTE = is buruke] [QUOTE = text]
As I said in your car, there is a simple but economically losing breakdown. It was on my uncle's car. The car was running out of gas in two. It seems to have been in my old carburetor vehicle.
08.05.2020 15:07 # 15
striker76
I recommend that you keep the petrol level close to the tank halfway. As such, gasoline seems to decrease, decrease, but when you start the vehicle after a while, it shows the real level in the tank.
I could not start the car again from where I parked the car twice because gasoline was exhausted, even 5 liters of gasoline I bought did not bring the tank to itself. That's why I'm trying to keep the gas tank up and running.
