Lpgli 307 problems !!
08.05.2020 15:30 # 1
Angelo
Hello friends
The 2004 model peugeot 307 (petrol + lpg) automatic gear I bought a second hand a week ago had an error called antipollution fault after I bought lpg today. And at the same time, the car seems to consume considerably less gasoline, even when using the lpg. A master stops in gasoline, but the indicator drops. How ridiculous this is. How can we fix these issues? Thanks for your help in advance.
08.05.2020 15:30 # 2
anil307
Yes, it is so in the 307s. I had the subject. You can examine the LPG section.
anil307 2011-05-29 19:00:15
08.05.2020 15:30 # 3
metin
ahh ah. If you search the topic in the forum, you can find that it does not consume gasoline, that the needle drops, what things are related to the antipolition error.
08.05.2020 15:30 # 4
Angelo
Everyone said a lot of things, I'm confused Confused
Anıl307, how did you solve this problem?
08.05.2020 15:30 # 5
anil307
There is such a thing as psa module, it gets stuck under the seat, when every contact hurts and closes, it replaces gas level, but the room sometimes shows more gas than it is. I understand your psychology right now, you get annoyed, gas is burning, you are hair, but it does not burn, but all of them are there =)
08.05.2020 15:30 # 6
semih
I have the same problem with my 206. I couldn't understand why. Gasoline needle falls with the tube.
08.05.2020 15:30 # 7
metin
[QUOTE = Angelo] Everybody said a lot of things, I'm confused Confused
There is only one answer that doesn't tell everyone.
The working principle of the vehicle is completely electronic. Once the float receives gasoline, it measures the level once and notifies the brain. calculates the gasoline burned according to the km you drive in the brain (calm or fast) and reduces the gasoline needle accordingly.
While driving in LPG, the needle continues to fall as if the vehicle is going on gasoline. If you want the needle to become old, if you buy at least 7 liters of gasoline about 35 TL, the float will transmit the change to the brain, but the needle will be replaced, but it will continue to fall again. If you take less than 7 lira, the float will not tell the brain, the pointer will not play and continues to fall from where it left off. these are all french vehicles peugeot, citroen and renaultta.
As a solution, you will get the module psa module, this module allows the float to transmit the level to the brain and lift the needle as if you have received new gasoline every time the ignition is turned on and unfortunately it drops again when the needle is going, it turns on the ignition, it comes back to its old level, it drops again when it goes, so there is no other remedy, it always drops while it is on the way. there is nothing to wonder.
08.05.2020 15:30 # 8
diabolicfb
Welcome to the club :)))))
08.05.2020 15:30 # 9
[QUOTE = text] [QUOTE = Angelo] Everyone said a lot of things, I'm confused Confused
my brother is right.
This situation is not a problem or a malfunction, but a situation that arises in relation to the structure of the vehicle, as the text explains. I heard from a few people that more than half a tank of gasoline is kept in place when the ignition is turned off.
or you can install a role or psa module. In this case, no matter what level your gas is, turn the ignition back to normal when it turns on.
08.05.2020 15:30 # 10
helot
antipole. I was getting the error, the engine malfunction lamp was on, I brought the LPG service, my master was fine, he corrected the error with a very good setting. A very fine tuning is required. When it comes to the problem of needle drop, the psa module (expensive), if the gas tank is more than half, you can stop and find the needle in every forum you run or find a cheap solution (I applied it). It is not a problem to be worn on your head, but the malfunction of the malfunction lamp is annoying.
