Lpg winter setting
08.05.2020 17:13 # 1
ertanakar
My friends car 206 1.4 x-desing, I want to keep my car at an economic level in winter conditions.Tartarini brand has lpg.It was burning 27 cents per km with 17 inch steel rim, now it has increased to 30 cents, and also increased the distance with gasoline. - If we go to the LPG setting, I would be glad if there are friends who know what problems will happen if I drop it to the lowest rates.
08.05.2020 17:13 # 2
offchu
If the LPG has a winter setting, sorry I heard it for the first time! In the meantime, in cold weather, you know, you can not show the reason that you cannot get efficiency from LPG vehicles, because the gas does not like cold air and the transition time of the vehicle to gasoline increases, thus increasing the fuel consumption. you can go to the gasoline to go to your master and play with the injector, so that it passes in a shorter time than usual, but this can damage the brain of the lpg car when the temperature of the carbirator water becomes 40 degrees.
