LPG Usage in 307 1.4 gasoline 90 hp vehicles
08.05.2020 21:04 # 1
ismailkaya
Selamunaleyküm friends Friends driving 1.4 petrol 90 hp 307 and 207 LPG vehicles. I wanted to share all the things to be considered when using LPG in this engine versions in this form.
Best fit LPG kits are expensive. I have Atiker Grant LPG kit, which is my vehicle 307 1.4 petrol 90 hp. my problems;
Although it is rare where it stops, the LPG brain does not perceive this change, as the LPG and the engine change the operating system while turning on the air conditioner, fan and headlights of the vehicle, and there is a problem of fluctuation or stopping at the idle. To get rid of the problem, it is best to turn the vehicle on and off while it is in motion and there are no problems.
08.05.2020 21:04 # 2
My teacher lpg job is more than the brand, the most important point is compared to the engine of the master vehicle. You can ride the 307 engines with a good workmanship compatible with many LPG brands in the market. I got my atiker obd2 kit on 206 vehicles and got on 80000 km without any problem. Neither idling fluctuation nor engine failure light. Now I have 308 vehicles fitted with prins technomax kit. It was 18000 km. Thank God I did not have any trouble. Because it will be suitable for the vehicle. Now, I have created a different sentence based on my first comment above, but unfortunately the engines like the new generation euro 4 and 5 are not suitable for every lpg kit. But there is no problem in your vehicles. Now, for example, where it is stopped, air conditioning etc. when you open it, you said idle ripple etc. As I said, I did not encounter such a problem in two of my vehicles, you do not encounter such problems with good workmanship and good calibration.
08.05.2020 21:04 # 3
arslan_ozkan
I use 1.4 gasoline 307. You will not have a problem if you set the ripple problem at idle to run on gas while the vehicle is moving when the vehicle is stopped. Gasoline consumption is increasing, but the engine runs more efficiently.
