Lpg stop problem.
08.05.2020 16:19 # 1
Ucyuzalti
First of all, good night everyone, I became a new member, I opened the subject right away, I hope it does not seem to be a member to ask questions, because this is not my intention.
& nbsp; & nbsp; & nbsp; MY VEHICLE: My car is Peugeot `un & nbsp; The model of the 306 series is griffe, driver airbag, air conditioner, power steering etc ... 98 model hatchback 5 door model
& nbsp; & nbsp; & nbsp; THE PROBLEM IN MY VEHICLE: My vehicle stops at LPG these days and does not do this event at gasoline. makes unstable movements with down movements and eventually stops.
After stopping the vehicle, I run it again, the system works on gasoline as required, but there is no stopping or fluctuating idling. I thank you for reading and interested in my message. Reviews
08.05.2020 16:19 # 2
mhakan71
clear throat butterfly
08.05.2020 16:19 # 3
by_imp
I do not understand from lpg, but if the problem is only in LPG, it may be in the fuel system, so it may be getting the LPG fuel unbalanced.
08.05.2020 16:19 # 4
Have the lpg idle setting check the air inlets and, most importantly, the spark plugs. In addition, make sure that your car's water is not missing.
08.05.2020 16:19 # 5
Ucyuzalti
water does not decrease at all, satin and new 3 liters of antifreeze and 3 liters of water and put the lid closed. We will go to the LPG service tomorrow. It never happens in gasoline, I don't even understand it's cold like this, the car is running `` wicked worm '' "Laugh" < editID> Three Hundred Six 2011-11-01 01:07:35
08.05.2020 16:19 # 6
Then review the lpg system and show the system's settings. Not all lpg systems are reviewed twice a year, full efficiency is not obtained. As a result, the summer is hot and the lpg is expanding, the winter is cold and the expanding lpg is shrinking. The system is unlikely to adapt. "isChromeWebToolbarDiv" style = "display: n o ne">
08.05.2020 16:19 # 7
Ucyuzalti
Thank you for your interest and concern.
08.05.2020 16:19 # 8
I always help. It doesn't even matter. Thank you. "Laugh"
08.05.2020 16:19 # 9
I had the problem when I first got my car. I had LPG Spark Plug installed on my vehicle with the suggestions of our CeCoLi brother and also cleaned the Throttle. After doing these, I have no problems. I recommend you to try it. Sometimes the poor quality LPG we get can cause this problem unfortunately, I suggest you pay attention to this issue ...
08.05.2020 16:19 # 10
Ucyuzalti
Yes, I bought a place on the satin samsun road from a place I have never heard before. These things happened.
What is the lpg spark plug like?
ÜÇyüzaltı 2011-11- 01 11:53:30
08.05.2020 16:19 # 11
Ucyuzalti
I bought lpg from municipal gasoline today and the car recovered spontaneously after a while (500 mt). Hopefully it will not repeat & nbsp;
08.05.2020 16:19 # 12
If it repeats, as I said, direct your attention to spark plugs. You can find BOSCH Platinium-Iridium Spark Plug from Bosch Car services and have it installed at the same service.
08.05.2020 16:19 # 13
Ucyuzalti
"Bosch Car services BOSCH Platinium-Iridium Spark Plug" is not available in Çorum, I think this is "Laugh"
Üçyüzaltı 2011-11-01 19:52:48
08.05.2020 16:19 # 14
Ucyuzalti
The vehicle repeats the problem in cold weather "Unhappy", do we know how much the prices of spark plugs you call?
08.05.2020 16:19 # 15
alisuat
4 of them were around 100 TL, I think I am not sure if you clean the throat butterfly, your problem will pass.
08.05.2020 16:19 # 16
http://www.boschservice.com.tr/en/en_yakin_bcs
You can check the service at this address. When I looked at it, I saw that it was also in Çorum. "Grin"
Spark plugs like an average of 50 TL with service. it costs a figure. But I definitely recommend you to clean the Throttle ...
08.05.2020 16:19 # 17
In addition, all parts of LPG & nbsp; should be checked ... From the clamp at the mouth of the hose to the edge insulation of the nozzles. If there is a fluctuation or irregularity in the idle, it should be considered thoroughly. Parameters in Birde settings should be checked. Sometimes it can be experienced because of the wrong choice of spraying setting. Some craftsmen don't know our engines. When they set the engine which needs to run full group, it is always a problem. Let the full group be crazy in your engine. As soon as you change the spraying setting of a properly working engine, it starts to deteriorate at idle, etc. vs
& nbsp;
I'm really tired of peeling, but let me peel one more time. Such problems may not be the fault of the engine, lpg fuel, or lpg conversion kit. The biggest and most basic suc "master" ...
CeCoLi 2011-11-04 07:18:02
08.05.2020 16:19 # 18
Ucyuzalti
I am glad that you are well here "Laugh" describe our upstream industry, let me see, thanks for the information.
08.05.2020 16:19 # 19
Ucyuzalti
I went to the LPG service today, the master who saw the car saw that it had recovered when it warmed up and said that we would raise the temperature to me. When I went before, when you connected the pc as you said, there were lists in the program that opened in the pc and it was written in order and changed it to the master group. The temperature of the current vehicle is 25 degrees, we will do this 35, since I bought the car, I did not change the specific spark plug, I will plug it in as soon as the friends say. Good night ...
08.05.2020 16:19 # 20
Ucyuzalti
Don't stop friends & nbsp; my problem still continues, I have always used the car in gasoline
this happened after stopping the antifreeze problem, then to overcome the problem;
I changed the thermostat
I changed the air filter
myself the filter the boiler was there, I cleaned all the pipes that came there, it was like new. Unfortunately there is a voltran here, just looking for a place, the room says everything will change the injector. Previously, the car was switching to gasoline, then it would replace parts, the suction hose burst and we went straight. I am very happy with the car going out of fuel, but it does not have a stop ... And it all happened after the anti-antifreeze, either it has something to do with it. From the friends who have knowledge about the lpg topic & nbsp; I am waiting for an idea
Page : / 2
