LPG SINGLE WARNING AND FINISHED EMERGENCY
08.05.2020 17:18 # 1
haSAN_307
Friends, everyone, I'm going home yesterday evening, the car gave a lpg warning and I was stuck. Normally, after giving a warning 20 km more easily, it did not go 1 km behind the warning, it was finished in petrol. Now my main question is:
ordered I use the system atiker and when the lpg is over, after the warning sounds, the car passes my gas and continues on the road or does it continue until the lpg ends? & nbsp;
08.05.2020 17:18 # 2
Barut
After giving a beep, it immediately switches to gasoline and the car stopped because it is not in petrol.
08.05.2020 17:18 # 3
haSAN_307
So, as soon as the warning sounds, is the lpg finished?
08.05.2020 17:18 # 4
Serkan
Hodja, keep the button pressed on the lpg indicator and start the vehicle.
08.05.2020 17:18 # 5
haSAN_307
I did not fully understand, obviously, after the lpg warning sounded, is the gas completely finished? Because it gives warning while I'm on the go. When I run it by pressing the lpg indicator, does it work directly with LPG?
08.05.2020 17:18 # 6
Serkan
Yes, by holding down the button on the lpg indicator, it works directly on the LPG, you can understand by pressing the valve on the tank filler, the lpg is not finished yet, but it can be dangerous. yi
Serco05 2013-01-20 13:46:10
08.05.2020 17:18 # 7
KenBlockJR
If gasoline is exhausted, the gas pump may burn out, do not force too much. Put the gasoline directly on it.
08.05.2020 17:18 # 8
ufuk91
Of course, as soon as I warned, I also had an atiker, when I went to change the tank float, I had a lpg in it, and bring it to the mortar. When you switch to gasoline, the vehicle is already clear, you press the button on the LPG and turn it off again.
08.05.2020 17:18 # 9
haSAN_307
"holding the button directly works in lpg" & nbsp; this is fine :) then let me ask one more question & nbsp; & nbsp; type & nbsp; direct lpg damage to the vehicle when I run it?
08.05.2020 17:18 # 10
haSAN_307
[QUOTE = ufuk91] As soon as I warned, of course, I also had an atiker, when I went to change the tank float there was a lpg in it, bring it to a little charge, said the master (the light was red and once warned) I went out to Istanbul road at least bi 20 30 km I barely finished, when you switch to gasoline, the vehicle is already clear, you press the button on the lpg and press it again, it goes back to lpg [/ QUOTE]
& nbsp;
on me & nbsp; I knew that way, I was surprised when the song was over and I wonder if the car pulls my gasoline.
08.05.2020 17:18 # 11
haSAN_307
Thanks to everyone for your nice information :)
08.05.2020 17:18 # 12
Serkan
[QUOTE = kayseri_307] "works directly on lpg by holding down the button" & nbsp; that was fine :) then one more question Let me ask & nbsp; & nbsp; type & nbsp; will it hurt the vehicle when I run it directly with lpg? to run when you stay
08.05.2020 17:18 # 13
haSAN_307
[QUOTE = Serco05] [QUOTE = kayseri_307] "works directly on lpg by holding down the button" & nbsp; this was fine :) then a question Let me ask for more & nbsp; & nbsp; type & nbsp; will it hurt when I run it directly with lpg?
& nbsp;
thanks :) thank you
