LPG SHOWS FINISH
08.05.2020 18:47 # 1
orhnist
I GET 40 TL GAS TO MY VEHICLE. I went 1 km. SHOULD I TAKE GAS AND TRY AGAIN FROM YOU FROM THE LOCATION, OR I WILL USE GASOLINE UNTIL IT TAKES MASTER
08.05.2020 18:47 # 2
zr`lmn
Is the LPG station always your pick? Or did you take it to try. The same situation had happened to my friend and he tried not to finish the LPG, but he had to use it in gasoline for nearly 3 months.
08.05.2020 18:47 # 3
Efe-Pojo
start the car in the tube then it will not switch to gasoline.
08.05.2020 18:47 # 4
orhnist
the station I bought every day then went and bought gas from another station but the situation did not change again
08.05.2020 18:47 # 5
fætih
lpg cannot be finished. It is impossible to finish 40 tl lpg in 1 km. but there is a problem somewhere. run directly on the gas and hit a little red line. injectors may have trouble.
08.05.2020 18:47 # 6
orhnist
[QUOTE = fætih] lpg cannot be finished. It is impossible to finish 40 tl lpg in 1 km. but there is a problem somewhere. run directly on the gas and hit a little red line. injectors may have trouble. [/ QUOTE]
we found the trouble that the cables entering the injector came out, so the car does not switch to the tube
