LPG Shaking-Idle flickering problem
08.05.2020 15:07 # 1
sfyucedag
Hello friends,
My 2001 model 306 xr platinium vehicle is Milan brand sequential system LPG. I reside in Ankara.
While my car is trouble-free with gasoline, it does not react to LPG as much as I press the gas, it shakes by shaking.
The LPG driver said that the LPG injectors of the vehicle should be changed, the mechanic glued directly to the coil.
I am waiting for your help if there are friends who have experienced this problem, heard or are experts in the subject.
08.05.2020 15:07 # 2
metin
[QUOTE = sfyucedag] Hello friends,
I don't know the same problem, but my father-in-law had 99 models of opel astra. The vehicle was going very well on gasoline, but the LPG does not eat gas especially on departures, shaking, getting up late, drowning.
Everyone went to everyone, no one could not solve, where they changed all the parts, but we went to a master, he tried just by inserting the bobbin in his hand. The problem was solved.
you can be from the coil I want to tell, you can solve it with trial and error system.
08.05.2020 15:07 # 3
sfyucedag
I will borrow the coil from my familiar peugeot particle, then my brother, I will have it installed. I hope it passes like your father-in-law. I will take my coil. If it does not, continue to try. Hard work ...
08.05.2020 15:07 # 4
sfyucedag
Today, we replaced LPG in the injector and the vehicle's shaking and shaking stopped.
Right now my vehicle is going in the same situation with gas, just like with gas.
08.05.2020 15:07 # 5
metin
Get well soon.
As I said, the solution is reached with trial and error method.
In fact, the problems in the vehicle are more evident in LPG. You can solve the problem before it grows.
For example, if this problem did not manifest itself in LPG, you would still be riding like this since it did not show up in gasoline:
08.05.2020 15:07 # 6
[QUOTE = sfyucedag] Today, we changed the LPG on the injector, the shaking and shaking of the vehicle was interrupted.
Anyway, it's okay to get over the problem ... :))
08.05.2020 15:07 # 7
kaan__
did you solve the injector with the coil or the coil?
As far as I know it should have been expensive in the injector in the coil, let's know how many things we will do if it happens to us again.
Teşşekürler ...
