lpg setting
08.05.2020 17:33 # 1
osmntskn
greetings,
Finally, I got my 206 lovato. Thanks to Allah, he has made 3 thousand km right now, there is no problem (except for gasoline needle drop)
my trouble is that the car passes from gasoline to the tube at first start, to me, I asked the master, the factory setting was 40 degrees, he made me 30. However, it seems to me that it is too late, except for the lunch heat. I went for 2 km at night, the temperature went up to 80, but it went to the tube, in the morning,
I am already going 10 km. If we go with it, there will be no profit.
What is the advice of experienced friends to this situation?
08.05.2020 17:33 # 2
hsnsnl
I think it is okay if it is night after 2km, my teacher, it is very good in this weather ..
08.05.2020 17:33 # 3
rolandgarros
Unfortunately, I know the situation is the same for other vehicles. Thumbs Down
08.05.2020 17:33 # 4
maestro
Is the car temperature rising to 80 after 2 km at night?
08.05.2020 17:33 # 5
Bunyamin.Kar
Hodja, I had the same problem, I said that it is passing from the gas to the tube while making the tube adjustment.
08.05.2020 17:33 # 6
rolandgarros
[QUOTE = Bünyamin.Kar] Hodja had the same problem with me, I said I was passing late from gas to tube while making the tube setting.
This is what they call vala practical solution LOL Bravo
08.05.2020 17:33 # 7
osmntskn
[QUOTE = maestro] Does the car temperature rise to 80 after 2 km at night?
Because I live in my teacher Artvin, everywhere is a ramp ..., it goes up to 80 in 5 km while descending to the creek, it goes up to 500 meters while going up ...
08.05.2020 17:33 # 8
osmntskn
consequently, it is not a problem that it passes from gas to tube late, thank you. Meanwhile, it burns 20 cents on the long road, I'm very happy with the fuel.
but where should I buy the lpg, I bought it from the shell, some of them said it was very thin, it burned it.
08.05.2020 17:33 # 9
Bunyamin.Kar
[QUOTE = osmntskn] consequently, it is not a problem to switch from gasoline to tube, so thank you. Meanwhile, it burns 20 cents on the long road, I'm very happy with the fuel.
I usually buy from opet and also from Aytek
08.05.2020 17:33 # 10
samet206
it is adjustable but it is not bad for fine tuning.
