LPG removal from the license
08.05.2020 21:23 # 1
cem0204
Hello,
In the 2008 model 308 vti I just bought LPG was installed but we had it removed. At the same time, it was necessary to remove it from the license until the inspection time. Inspection of the vehicle in June. What do I have to do to get it out of the license? Our reason for dismantling LPG; VTI engine compatible LPG was not installed, the previous user used it for a while and obviously the vehicle started to give a warning later. He himself, in some way, combined the cable from the vehicle with cheap labor and canceled it, but still damaged the vehicle. The other day we had it removed, but you have to remove it from the master license, the project needs to be drawn. Can you give detailed information? Thanks.
08.05.2020 21:23 # 2
The procedures to be done to disassemble the LPG system from a vehicle that has been autogas mounted and processed to the license and to drop it from the license & traffic registration are as follows:
1-First of all, the LPG system of your vehicle should be dismantled in an authorized Autogas service.
2- A lpg dismantling project should be prepared by a company that is authorized to design a serial modification project (AITM) for this dismantled vehicle.
3-With the prepared LPG dismantling project document, it should go to the inspection station.
4-LPG from the vehicle inspection station (TUVTURK) As the vehicle traffic you have passed, the LPG phrase has been deleted from the registration of the traffic and the new licenses must be obtained.
08.05.2020 21:23 # 3
cem0204
What do you think is the average cost for these?
08.05.2020 21:23 # 4
bilo131
Last month, I had my vehicle lpg installed and examined. inspection fee 280 TL. issue a new license 170 TL. you will pay the same possible charges. But if you plan to have it done after January, I heard the rumor that the inspection fee will be 330 TL. issuing a license is at least 200.
08.05.2020 21:23 # 5
arasemre
The document you received from the place where the tube was removed has a validity period of 1 month. Otherwise, you pay the fine ...
Or ...
1- You give qidip to engineering project company and give you 700tl to all the necessary documents of the vehicle and you get a visa without interfering with anything else. They even arrange the dismantling invoice. (They want 700tl in Izmir)
2- You pay the visa fee and enter the visa and give the documents there (how much the examination fee is)
3- The leaves are changing to operate in the license (how much the license leaf is)
According to bilo131's writing: 700 + 280 + 170 = 1150tl
In June, before the vizen comes out before this month, it will be a good hike as every year.
08.05.2020 21:23 # 6
cem0204
Namely; Cables on the motor side of the system were removed from the vehicle. The tube still remains in the trunk. They said that if you come 15 days before going to the inspection, you can get the project drawing and we can also remove the tube. They said you should go to the examination with that document. There are a few other shortcomings for the vehicle to go through the inspection, but I will have to complete them, but the financial conditions ... So, until June, (Inspection date), I am thinking of removing the other defects and removing the last tube. I don't know if it makes sense. As you said, it will be a little hike, but unfortunately it will be like this :(
08.05.2020 21:23 # 7
Karacocuk24
I respect the idea of my teacher, but it seems like it will exceed 1000 liras, which is understood for the fitting, instead, I think it would be better if you go to a specialist LPG service and update the system.
