LPG red light
08.05.2020 15:41 # 1
cetin
On the LPG fuel gauge, how many kilometers can we go on average after the red light comes on. Shocked
08.05.2020 15:41 # 2
[QUOTE = hard] How many kilometers can we go on average after the red light is lit on the LPG fuel gauge. Shocked [/ QUOTE]
You cannot get a definitive result in the lpg indicator because those indicators show the estimated amount and are variable.
08.05.2020 15:41 # 3
I don't think too much about those lights.
There will be a little bit of narration, but do the following:
Fulle your vehicle's LPG tank until you're done. Then calculate how many kilometers with fulle, how many liters of LPG you go, you know how much your vehicle burns per kilometer. If you keep this account in mind, you will know how many kilometers to go with the amount of LPG you bought.
08.05.2020 15:41 # 4
sercinho
What if the LPG indicator in the tanks is showing properly, I don't think if I do not show the imbalanced sanc 4 and 3 lights too quickly.
08.05.2020 15:41 # 5
[QUOTE = sercinho] Does the lpg indicator in the tanks show properly, I think if I leave the unbalanced bank 4 and 3 light too quickly, does not show it completely, it is perceived a bit later after getting the LPG [/ QUOTE]
4. If the 3rd lights go out very quickly and the 2nd 1st lights run out late, I think there is a malfunction in the LPG sensor.
It does not show correctly when the first contact is opened after filling LPG. Turn off the ignition, wait 5-6 seconds, turn on the ignition again, and start the starter after 5-6 seconds.
08.05.2020 15:41 # 6
right sercan simit tanks don't show the indicator properly i have the same problem when i asked my friend lpg ci he said the same thing
08.05.2020 15:41 # 7
I have the same problem and my friend's car, guys. The 1st and 2nd light goes very quickly. There is a maşallah in red, the vehicle is going 100 km. Sırıtma
I do not care about the lights since I use it by calculating km. Otherwise, when the man eats, when you're done.
08.05.2020 15:41 # 8
sercinho
thank you brothers, lpg in the lpg is burning a little bit now, the leaks i'm using a spinner 265 burns the mercury high I have already decided to use it anyway
08.05.2020 15:41 # 9
[QUOTE = sercinho] thank you brothers or lpg in the moment it is burning a little bit of puffin
18 krş intercity city 25 krş sercan brother
08.05.2020 15:41 # 10
25 cents is normal at high rpm. You can drop up to 20 krş in calm use.
08.05.2020 15:41 # 11
sercinho
yes, it is time to use. If you use it, there will be no problem.
08.05.2020 15:41 # 12
[QUOTE = erhanomer] [QUOTE = sercinho] thank you brothers or lpg is burning a little bit now, the leaks I am using it all round 265 burns burns high I have already decided to use it
erhan is valid for 20 krş manuals that you say, but we get our automatic attention ...
08.05.2020 15:41 # 13
maestro
I know this is an adjustable condition, not a malfunction
08.05.2020 15:41 # 14
sercinho
[QUOTE = ose307] [QUOTE = erhanomer] [QUOTE = sercinho] thank you brothers or lpg is burning a little bit now, the leaks, I am using it for a while, I'm burning 265 mercury, I have already decided to use it.
automakers want to burn more than you want. Is there any opportunity for use in the city
08.05.2020 15:41 # 15
[QUOTE = sercinho] [QUOTE = ose307] [QUOTE = erhanomer] [QUOTE = sercinho] thank you my brothers or lpg is burning a little bit now, the leaks are on my knees, I have been using it, I have already decided to use 265 mercury high now
I will not see the benefits of cc, no pleasure and savings, at least 1 liter per 100 km.If you are in the city, you can use it if the road condition is available.It can be engaged at 3rd gear 50 km / h.
ose307 2011-06-23 17:22:45
08.05.2020 15:41 # 16
sercinho
[QUOTE = ose307] [QUOTE = sercinho] [QUOTE = ose307] [QUOTE = erhanomer] [QUOTE = sercinho] thank you my brothers or lpg also burn a few kurus, leak, i will use it again, i declare to use 265 mercury high now
Is it possible to use the brother in the city
08.05.2020 15:41 # 17
If the road is empty in the city, you can use it. In order for the CC to be activated, the minimum speed must be 3 and 50 gears and above.
08.05.2020 15:41 # 18
sercinho
[QUOTE = ose307] If the road is empty in the city, you can use it. The minimum speed must be 3, the speed is 50 and above, in order for the CC to be activated.
Thank you, let me put up with my brother.
08.05.2020 15:41 # 19
[QUOTE = sercinho] [QUOTE = ose307] If the road is empty in the city, you can use it. For the cc to be activated, the minimum speed must be 50 and above, the gear should be 3, I use it when I come to work on the airport side by car. [/ QUOTE]
Göral installed software and arm for 200 TL.
08.05.2020 15:41 # 20
sercinho
I wonder if I needed software, because of the last LPG, they had thrown the software.
Page : / 2
