LPG recommendation
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
08.05.2020 20:28 # 1
xxozmozxx
Greetings 208 1.2 vti etg5 I have a 82 hp vehicle.
I want to have lpg, my fuel consumption in the city is 5.1lt / 100km in summers, 6lt / 100km in winters
I have 500-600 TL fuel consumption per month.
I would be happy if experienced friends share their knowledge.
I live in Ankara.
xxozmozxx 2017-07-24 14:22:33
08.05.2020 20:28 # 2
Peugeot35
Atiker GRAND plug back.
There are explanations about the subject.
08.05.2020 20:28 # 3
KILIC
your fuel consumption is very high. how many thousand km per month you are traveling.
08.05.2020 20:28 # 4
First of all, welcome to us. I do not recommend vik engines atiker brc or prins brother
08.05.2020 20:28 # 5
tsufrankwoli
https://www.youtube.com/watch?v=ljeihr10n00
I think go to Istanbul and have it installed. You will be both.
08.05.2020 20:28 # 6
ggitaristt
Handshake LPG recommendation >> Installing
Editing: I wrote a lot of things while editing. I did not like what I wrote, I deleted all of them back.
ggitaristt 2017-07-25 01:49:18
08.05.2020 20:28 # 7
OguzhanKucuk61
5.1 liter fuel consumption is already quite low for a gasoline vehicle. There is no need to interfere with the vehicle with LPG. Do not tire yourself, since the car that burns 25 cents will burn 20 cents. I think your very good values.
But 500-600 ₺ a month is not a small amount. It means you are doing a lot. In this case, you will get a diesel vehicle with a volume of 1400 cc. I think you will be satisfied with 4 - 4.5 liters of fuel consumption.
08.05.2020 20:28 # 8
KILIC
I agree with oguzhana. If you pay 500-600 TL gasoline per month, you are traveling at least 2000 km per month. I think the budget you will give to LPG with 1,2 engines is not going to go this way, which is around 2250 TL with the least license procedures to buy the car and buy diesel. your fuel consumption will be halved in a month and you will get the money out of the car. you have a car that goes like a monster on the road. Of course these are my thoughts.
08.05.2020 20:28 # 9
ykayan
I have 206 1.4 automatic vehicle, it was burning 48-50 krs in gasoline, I had atiker gold burning now it is between 21-25 krş. If you install an atiker, take a look at the injectors of the model you have installed and compare the ones installed. Another LPG player warned that they had an injector lower than 300 TL in mine. Models of Atiker such as Gold, Grand etc. are completely the name of the injector system.
08.05.2020 20:28 # 10
gaspart33
hello friends 208 1.2 vti I had my atiker grand kit with my motor vehicle there is no problem now, there was no performance loss event, I did not feel it but there is a problem of gas gauge when i go to buy lpg, the indicator is improved when i get 20 tl of gasoline, my fuel consumption is around 40% petrol lpg difference now the situation of the road and just the obvious difference in the city, this work is very good if it is the place that assembles very well, my financial power is not enough for brc or prins atiker grand I got a 130 kw regulator for a 60 hp 60 kw engine and romano injectors are feeding the car enough about lpg manifolt If the regulator is connected from the nearest point and the injectors at a short distance, it does not matter if the regulator is connected to the middle of the radiator core and its alignment.
08.05.2020 20:28 # 11
emrah_860
I think the refueling fuel normal vehicle is already having problems with 1.2 traction or change the car 1.4 buy a vehicle with engine
08.05.2020 20:28 # 12
fatihsultan
dont get it bro. go buy a diesel car.
08.05.2020 20:28 # 13
gaspart33
I want to transfer 1.2vti engine lpg use after a long break, since it is the winter month, 0.20 krş in city use on long road lit 27-28 krş in summer, these rates will decrease a little more in performance performance loss for a vehicle with 1.2 vti and 61 kW 118nm torque I I do not feel it now, for those who say it is a pseudonym, I use it a lot in the city. There was a gas cost of 400 TL per month. He can ride without problems with
08.05.2020 20:28 # 14
maximusti
Even diesel is not a solution for someone who gives 500 600 per month,
will come to the most suitable lpg.
The most important issue in lpg is mounting, after the installation is messed up, install as many prins as you want.
I get an average of 100 150 TL per month, and since I use a short distance in general, the vehicle does not give me an advantage in diesel or LPG. but for those who buy fuel over 300 400 lpg is a blessing.
08.05.2020 20:28 # 15
KILIC
[QUOTE = gaspart33] I want to transfer 1.2vti engine lpg use after a long break, since it is the winter month, it burned 0.20 krs 27-28 krş in long distance on the long road in summer, these rates will decrease a little more in terms of performance 1.2 vti and 61 kw 118nm torque I did not feel a loss of performance for the vehicle, now I say for those who call it, I use it a lot in the city. There was a gas cost of 400 TL per month. friends who want to can get on with a good assembly without problems [/ QUOTE]
Where did you get lpg?
08.05.2020 20:28 # 16
ggitaristt
You don't have to worry about it .. But the friend who opened the subject already had an average of 30 cents, there is no point in having lpg and burning 30 cents again.
08.05.2020 20:28 # 17
Gokhan d.
LPG always saves 35-40% compared to gasoline. Even if you pay 100 lira per month, it is not less than 40%. They are already doing it in installments and self-pecking. Prins teknomax is enough for your car
08.05.2020 20:28 # 18
Karacocuk24
I have not been in traffic for more than 50 krps, 24 krs per day, I have been traveling for 35 km every day. Karacocuk24 2018-02-17 00:22:21
08.05.2020 20:28 # 19
gaspart33
first, hello atiker grad I had the Gaziantep fortune auto gas also made this a very good assembly, they prioritized they connected the injectors from a short distance, dismantled the manifold, they said from the close point, they connected the injector hose 5 cm with the manifold and the hose between the regulator and the injector is 40 cm, so the gas entering the engine is within a short distance. I did not feel the loss of performance, I use the traction on the ramps, I use the city very well. Although most car manufacturers stop disel car production, everyone needs a different car, although it is 208 1.2 vti engine 3 cylinders. the compatibility is fine, regardless of which kit you connect, remember that the event assembly also ends good forms
08.05.2020 20:28 # 20
gaspart33
The city structure and roads affect the traffic very much, the people who use fuel consumption have a le ramp in a flat city and the fuel differences on the bumpy roads will keep the same fuel values and for this reason, it is very advantageous compared to gasoline with 100 liters of petrol and 100 liters of lpg. Seeing the difference between km, the lpg kit is already taking out the money, I made 1080 km with 350 tl fuel in the city.
