lpg problem
08.05.2020 14:15 # 1
yolgezer
Friends, I got peugeot 206 ma londrenzo brand lpg. But the gas gauge goes down to the bottom and stays there as if it is going on gasoline. Service Peugeot said that this was also happening but they could not solve it. Is there anything that can be done about this, a kit is mentioned somewhere but I do not fully understand, frankly at least how and where can I find a solution to this.
08.05.2020 14:15 # 2
BuRCaK
Do you have a trip computer in your car? When gasoline is sapıtıy gössterge trip computer and more I think that the kit did not come to Turkey.
08.05.2020 14:15 # 3
Onur
psa module is inserted, it falls down too but when the contact is closed and opened it goes back to the old level
08.05.2020 14:15 # 4
Almost all of the scuba pugs are having the minor problem you are having, so there is no problem to worry about ..
10 seconds from key to lock key to recover. just hold it down until it gets better then you get used to it even if it doesn't.
I heard that the kit in question was harmful to the vehicle.
08.05.2020 14:15 # 5
g-demir
A similar problem exists in my 307. I use the vehicle with sequential system lpg and I do not know how much gas is in the tank. Because I say it will be over, the level goes down. I turn the ignition off and on again, there is half a tank of petrol again. Sounds like I'm going to stay on the road somewhere one day, but let's see. I write if I stay on track Gülme
08.05.2020 14:15 # 6
You do not get on the road.You will know if the gasoline is running out or is not running at the first start or if the engine stops or kicks at 200m following the first start.
08.05.2020 14:15 # 7
BuRCaK
[QUOTE = laedri] The little problem you have is having almost all scuba pugs. So there is no problem to worry about ..
I could not understand if the contact was working while the button would be pressed for 10 seconds.
08.05.2020 14:15 # 8
If you hold down this key for 10 seconds after locking the vehicle from the door lock-unlock keys on the key, the hand will recover.
08.05.2020 14:15 # 9
yolgezer
I am going to try this key event :) Hopefully this will be the case.
08.05.2020 14:15 # 10
yolgezer
The key event did not work on my vehicle. Unfortunately, Burçak teacher does not have a trip computer.
08.05.2020 14:15 # 11
H-a-d-i
To the attention of new members! Click here let's 2010-06-06 07:49:31
08.05.2020 14:15 # 12
BAHTIYAR
The man who installed the gas was also in me. He said that he put 10 15 lira gas in each tank of gas. Sırıtma There is no other solution, there is the same problem in renaults, but it is reset when the contact is closed.
08.05.2020 14:15 # 13
fourus_06
[QUOTE = 06BAHO] The man who installed the gas said I put 10 15 pounds of gas in each tank of gas. Sırıtma there is no other solution, there is the same problem in renaults but when the contact is closed, our vehicles are divided [/ QUOTE]
this is the best solution. Alkış
08.05.2020 14:15 # 14
diabolicfb
:))) My brother, this inexperience, what a bad thing happened 1 week. I'm on the way to the friend news, I said, let me take a look at this awesome forum.
I said the gas gauge hit the bottom. Whatever I said :) I hope there is a solution.
