LPG Problem?
08.05.2020 19:48 # 1
adem61
I had my 2011 model 206+ vehicle lpg nearly a year ago. I had no problems for six months but when the engine of the vehicle was cold for a while, it seems to stop when I start it, the engine sound changes, it does not vibrate and does not gas, and then it recovers. It takes two seconds and then starts to eat gas. The master who wears the LPG said that the LPG should be introduced to the brain of the vehicle. When I run in the morning or when I want to move when the car waits for an hour parked, the master who wears LPG said that I would have no problems, now he says that I have a master in the industry in Ankara and I have to get it done by the other masters. Is there a master in Ankara who you know as an expert in these subjects?
08.05.2020 19:48 # 2
Adem hocam lpg brand, what is important is the 1st question, of course, the solution is most likely the problem is related to the lpg installation or the wrong setting.
08.05.2020 19:48 # 3
Vefa
Hope my brother, God help me, I hope you will find a solution soon. I hope they will not come across the empty masters like me and cool them out of the car. I hope you find me a solution.
08.05.2020 19:48 # 4
adem61
The LPG brand of my vehicle, AKL, told me that Peugeot vehicles are compatible with this brand. The odd thing is that when the car first started working on the gas and doing the problems I mentioned again, I made a peugeot master from the outside, connected it to the computer and adjusted the idling and throat throttle. The lpg issue also improved when the butterfly adapted, but it happened again two weeks later. I was getting to the center.
08.05.2020 19:48 # 5
adem61
The province does not matter, for me, even if I have a good master, I even took it out of Trabzon.
08.05.2020 19:48 # 6
Cyrus35
If the vehicle is working in a poor mixture and when it stops fully, it hits an advance, it stops, it suddenly takes over and does the same situation on its own.
* Crank speed sensor (the symptoms you mentioned in this fault will appear.)
* Butterfly cleaning, if it works on gasoline, if the car does the same problem, if it is doing the same problem, ignition and spark plug set should be checked, map sensor, oxygen pressure sensor should be cleaned and its soundness should be checked. If you found it, you can do your own control and cleaning processes yourself. In the worst conditions, you can inform your mechanic in this way.
08.05.2020 19:48 # 7
Vefa
Brother had the same problem in my 306. They made it from injectors, we gave 300 pounds, then the problem continued. He said the tube brain, we changed it again, another master said, I took it from the plot. I got 206 hdi now, my head is comfortable, my brother, the important thing is to find the pini.
08.05.2020 19:48 # 8
Htc
I had the same problem, and when the gas pump was replaced, the problem was over.
08.05.2020 19:48 # 9
mmuussaa
I have a similar problem with me. The car pushes itself back while on the move. People who play the game know that I am lag in real life: D I have been using this tool for 3 years. I made my expense to press down on the clutch to drop suddenly, idle fluctuations, and change it at least between 1500-2000. Whatever more money I received, I will change it at the earliest opportunity.
08.05.2020 19:48 # 10
kamilarangul
I had the same problem, even when the vehicle was in gasoline, it could not find the idle setting and took it to the master, looked at the attachments and the problem still continued, then directed to someone. There was a software problem in the vehicle, and I reinstalled the original software to the vehicle, and it was directed to a tube service, the room looked at the values by connecting it to the computer, thank goodness there is no problem right now. my advice is to have the car's brain checked.
08.05.2020 19:48 # 11
adem61
Yes, there was a software problem in the vehicle. They made software updates to the brain of the vehicle that I took to the service. There is no problem left, I hope it continues like this.
08.05.2020 19:48 # 12
Eyup B.
[QUOTE = adem61] Yes, there was a software problem in the vehicle. They made software updates to the brain of the vehicle that I took to the service. No problem left, I hope it continues like this. [/ QUOTE]
Good luck, master. While I was reading the LPG vehicle problem, I had an action, I think it is HDI and I think it has changed. Pejo HDI gas-efficient
08.05.2020 19:48 # 13
antyakn
teacher, read it if you are in the forum. There was a master in the bosom, there was no tube transitions about LPG and I did not handle it. I was very pleased. I couldn't remember the name when the tp on this street was going up in front of the gas station.
08.05.2020 19:48 # 14
JunioR56
2003 307 xt. I had a similar problem with me. When the vehicle was getting up, it was having a hard time pulling the back of the car when it found the car revolution. Finally, I said, I will remove the air filter and clean it. the former owner tied open air filter from below. I saw the place when I looked from above. plastic bottle, electrical tape and a few cable ties. my vehicle is back to normal. I have no problems with gasoline and LPG now.
