Lpg problem
01.06.2020 16:51 # 1
Orhan52
I used my car for a long time because I used my vehicle for a short distance, I did not think it would be a first thing because I used the vehicle with LPG, but I said that I would buy LPG today. I tried it 3 times. I would appreciate if you share
02.06.2020 10:01 # 2
It is necessary to check the lpg filter and energy sources. or if there is less gas in the lpg tank.
21.11.2020 09:40 # 3
Essentials
Nowadays I am faced with a similar situation. My vehicle, which works without any problems in gasoline, stutters in LPG, does not eat gas, and after 4 thousand cycles, there is only sound, no image mode officially. In the morning, I had fuel additives in petrol. Because I used less gas in the tank and this caused the gas pump to change. I put this additive saying there is dirt in the fuel system. I'll try a little and see what kind of result it will turn out
22.11.2020 17:49 # 4
ismailkaya
What is the engine version of the vehicle?
12.01.2021 08:54 # 5
Essentials
99 model 1.8 16valve teacher
