Lpg Misfire
08.05.2020 15:42 # 1
307kirmiziseytan
Hello, I have a 2004 model 307 Xr vehicle.
1 when my vehicle is in motion while working at lpg. My vehicle has a misfire style problem while going in gear. Let me explain by analogy, there is a problem in the way of pressing and releasing the drainage and leaving us in the shake back and forth. the same problem is less to be said in gasoline, but lpg also has this problem, thank you for your help in advance.
08.05.2020 15:42 # 2
metin
Hello there. Some non-perceived problems in vehicles can be felt more in LPG.
For example, I want to give an example with an event that happened to us before. The vehicle was shaking so little in gasoline that it was not eating gas in LPG, it was drowning, although we reviewed all the parts, we noticed that the problem was from the coil and the problem disappeared.
08.05.2020 15:42 # 3
I think replace your spark plugs.
08.05.2020 15:42 # 4
TarkanBassoy
I have that same problem. Tomorrow I will take the vehicle to 80000km maintenance. Spark plugs will change, let's see if the problem in me will be solved I'll let you know. The lpg doblo I used for work, which is likely to be caused by the throat butterfly, had the same problem. When the throat butterfly was cleared, the vehicle could be improved.
08.05.2020 15:42 # 5
bozaslan
thank you guys I'll try to solve this problem as you mentioned tomorrow.
& nbsp;
08.05.2020 15:42 # 6
tilbe307
You have cleaned the throat butterfly and got the calibration done and the LPG calibration made the car look like a clock :) My vehicle also had a worse. it stopped when it passed into the tube. it seemed to be singing all the time. now they are all gone, even the engine fault lamp has gone out :)
08.05.2020 15:42 # 7
fordtaunus
As friends have stated, gas adjustment and spark plugs should be the first step.
08.05.2020 15:42 # 8
TarkanBassoy
Today, the throttle was cleaned in maintenance, the spark plugs changed, now it works like clockwork.
08.05.2020 15:42 # 9
It would be nice if you add the brand and model of the lpg system in your vehicle to your signature.
Get well soon...
08.05.2020 15:42 # 10
tilbe307
Thanks to the sincere sharing of this forum and friends here, both the delivery to the address is determined and the problems are solved quickly when the people who experience the same problem share the solutions. This forum allows me to hold on to the pejo brand :) thank you everyone for sharing ... tilbe307 2011-06-29 13:06:05
08.05.2020 15:42 # 11
[QUOTE = tilbe307] get past, with the sincere sharing of this forum and friends here, both the address delivery failure is determined and the problems are solved quickly when the people who experience the same problem share the solutions. This forum allows me to hold on to the pejo brand :) thank you everyone for sharing ... [/ QUOTE]
+1
08.05.2020 15:42 # 12
bozaslan
thank you all for the problem caused by spark plugs.
