lpg is also running jerky.
08.05.2020 20:01 # 1
Hayrullah61
dear lion volunteers ...
Zavoli lpg is embroidered on my 307 vehicles. He started to jerky while driving, especially when loading the gas first and when I stopped in red. No problem with gas. I got the lpg master connected to the computer. `` C '' and `` D '' injectors make this shake. It stops when it turns off two injectors from the computer, it hurts again, the vehicle is running jerky. the master said these injectors need to be replaced. Can't it be contaminated? what do you think i should do?
08.05.2020 20:01 # 2
Honor, the problem can be disassembled and cleaned from lpg injectors. There should be 3 types of zavolini injector type, one of them is pan panjet and normal type injectors, pan and panjet expensive set is around 400 TL and I do not know if they are repaired. normal injector price should be around 110 TL
08.05.2020 20:01 # 3
Hayrullah61
I renewed two injectors and gave 300 TL including zero labor. Now it's like clockwork. Should I clean the regulator, or should I buy a new one?
08.05.2020 20:01 # 4
I'm glad your problem is solved, hodja. Do not believe that the best regulator is to replace the regulator, because the gaskets in it are getting old (due to using the room tool without antifreeze).
08.05.2020 20:01 # 5
Hayrullah61
I understand, thank you, teacher, for your valuable information.
08.05.2020 20:01 # 6
You are welcome, teacher, if we were able to help, we are happy.
