LPG Indicator problem
08.05.2020 18:37 # 1
Bysekowest
good day friends lpg indicator does not fall under 2 teeth falls to 2 teeth does not fall to one tooth, but when the gas runs out, it passes from two teeth directly to gasoline, rises when it gets gas, it rises up to 4 teeth but it stays in 2 teeth.
08.05.2020 18:37 # 2
Serkan
Did the problem exist before, did it happen spontaneously or did it happen after setting the lpg or something? Level adjustment can be made with the program, if it happened after the LPG adjustment, they may have broken the settings.
08.05.2020 18:37 # 3
Bysekowest
after lpg setting
08.05.2020 18:37 # 4
Bysekowest
Can I adjust it without touching the gas setting?
08.05.2020 18:37 # 5
Serkan
Yes, it can be adjusted without touching the gas setting. They probably reset the medicine before adjusting the gas and did not adjust the sensor. Serkan 2014-06-16 01:27:35
08.05.2020 18:37 # 6
Bysekowest
Thanks, I hope I'll have him look tomorrow.
08.05.2020 18:37 # 7
ahmed206
Yours was good again. In my old car, in the maintenance of LPG, the men exploded the bulbs of the indicator and then they said we did not.
08.05.2020 18:37 # 8
ByHack
Empty-full settings of the tank may need to be adjusted again. Have a check of the data coming from the float. There may also be a float problem ...
