lpg help
08.05.2020 16:01 # 1
morsii35
hello friends peugeot 306 xr 1.8 8v my car has atiker lpg, my car has been done for two weeks more, there is no problem in gasoline but they can not keep lpg setting, if you have acquaintances who can get help for lpg in izmir, I am waiting for your help, respect, love, good conversations ...
08.05.2020 16:01 # 2
In the meantime, it would be good if you could learn the model of the scar on your vehicle.
It can be Multifast or Fast. The situation may vary according to the continent. Has LPG filter and injector cleaning services etc. been performed?
Also write the km of the vehicle. And how long is it or km is lpg installed do you know that ???
08.05.2020 16:01 # 3
morsii35
At 166 thousand km, the lpg was assembled in 2006, I think it was the fast version. As I mentioned, the lpg was disassembled when I bought it. Parts such as tiny screws at the end were normally for 1.3 motor cars, they changed, there were filter changes.
Routine maintenance of the vehicle was made in 166 thousand, spark plug and spark plug cables changed. they said there is no problem. I bought the car from the private service, the engine is working strangely, gas feed, gasoline and LPG. I took it again, they changed the spark plug and spark plug cables, they took the format for 10 days. The master who assembles the lpg says that the operation of the vehicle is smooth and the problem is set in lpg. There is a problem with one of the ignition parts. Some say that the valve should be adjusted dior, I couldn't solve it, but as I say at the moment, when the service is running at idle, the speed decreases and rises, it sounds like 1303 torps, and I am surprised that I will listen to whom I will listen to. this is the situation.
08.05.2020 16:01 # 4
I hope your problem will be solved soon, man.
