LPG HELP
08.05.2020 19:12 # 1
akemal
I mrhb to 1.6x arkadaslar.peugeot 307 2004 models are automatic gearbox vehicle to LPG but too unstable to install a ıstıoy sevınırım if everyone is in Istanbul on branding and master different brands that might help housing soyluyor.b
08.05.2020 19:12 # 2
talip206
Master and assembly are more important than brand. My vehicle 206 automatic gear, I am very glad I got lovato. The malfunction light does not come on. There is no difference in performance. It is a very good search for the dealer you want to visit before making an LPG.
08.05.2020 19:12 # 3
akemal
I searched for a master, I am only troubled about the brand, I saw the good, I saw the expert, he said atiker, said something else, he was stuck in the brand consulate
08.05.2020 19:12 # 4
vpro
I have a lovato, the number ten lights up once in a while if I change the lpg I get, there is no problem outside of it
08.05.2020 19:12 # 5
rzy.dnz
Brc or prince if you call him a little expensive
08.05.2020 19:12 # 6
sezar206
A little luck. You coincide with a good master ins. I have atiker, I have been using it for 3 years, no problem. He had ten and zavoli from him, and he didn't have a problem, but I was doing more in the same warehouse and zavoli.
08.05.2020 19:12 # 7
tetik-soner
the master factor is very important ..... the one who complains from every brand is also pleased .... the atiker is cheap but it is the lowest kit ... the ones who put the top kits on the money are not complaining ... all I will understand according to your money ... this is for all brands valid so ...
For example, I shake brc is 1500 TL but it is a lower package .... like 1700 is the upper package of atiker ...
08.05.2020 19:12 # 8
Efe-Pojo
I have been using ATIKER for 10 thousand km without any problems, I don't understand whether ATIKER is too bad, fuel is also very good traction.
08.05.2020 19:12 # 9
blntctn
[QUOTE = rzy.dnz] Brc or prince if you say it is a little expensive, landirenzo don't wear any other nickname, never atiker nickname [/ QUOTE]
the friend never said; my vehicle is at 107.000 km, my vehicle is at 95.000 km, the tube was installed, and it was also 3.000 km. does not create, it does not matter much in performance, gasoline with the tube, the engine lamp was burned once.
08.05.2020 19:12 # 10
akemal
It is very interesting that those who use it do not have a lot of waste, but the masters are getting efficiency from the waste, they are very unstable. I have friends.
08.05.2020 19:12 # 11
rzy.dnz
Myself had not been in the previous car, it made me turn on the lamp, it caused problems in the cache, 3 times brain change, finally, I changed the complete system, I installed labdirenzo, then I got rid of it, I am still in the air, I would like to put it on my behalf, I would never wear it again, I would give it more than 500 600 rubles.
08.05.2020 19:12 # 12
rzy.dnz
3000 5000 km, I make an average of 180 200 km per day, the kms you say do not last for a month.
08.05.2020 19:12 # 13
pierson
The vehicle is passing to the gas too late..why may..when idling coincides it takes about 3 or 4 minutes ..
08.05.2020 19:12 # 14
KILIC
[QUOTE = pierson] Your car is switching to gas too late..why might..it takes about 3 or 4 minutes when idling also crashes. [/ QUOTE]
LPG temperature is high. It may be from him.
08.05.2020 19:12 # 15
talip206
LPG temperature is high, ideal 30 degrees. Don't wear too late. I think it is better to pass a little late in terms of the health of the engine because the engine has reached enough heat.
08.05.2020 19:12 # 16
vpro
If the car's engine is hot, plug it in, move the car a little, pass the car, and if it is cold, vPro 2015-04-07 20:07:38
08.05.2020 19:12 # 17
muhammed.ceyhan
Teacher, heat and speed are set high. They can reduce the heat and cycle in the service and make it pass earlier.
08.05.2020 19:12 # 18
muhammed.ceyhan
[QUOTE = akemal] Mrhba friends.I want to get lpg on my peugeot 307 2004 model 1.6xr automatic gear, but everyone is peeling different brands. brand and master I am happy if there is in Istanbul [/ QUOTE]
Atiker nanofast teacher. No problem..
08.05.2020 19:12 # 19
pierson
The heat gets at least ... When I look at it, the temperature bar changes to gas between 0-70 ... 36 or 37 degrees ..
08.05.2020 19:12 # 20
rizeli_53
my vehicle 206 1.6 110 horsepower (307 engine) gas swapped 7 months has been the brand of gas atiker. there are evil ones, I do not understand, I do not have any problems and my vehicle sees 190 whenever I want. a master's advice to you Istanbul kadosan ucel engineering you will be satisfied with your workmanship.
Page : / 2
