LPG FUEL
08.05.2020 15:13 # 1
ozi033
friends, with a gas of 40 TL, 142 km of urban area. 280 kgs per km is coming. It wasn't too much. I actually had a new lpg injection cleaning. Filters had changed before. I wonder how I can reduce it. Meanwhile, the automatic gear fault warning appears in me. Does it affect the fuel. Gokhan 2017-04-04 01:27:04
08.05.2020 15:13 # 2
coolpixsem
[QUOTE = ozi033]
Cem has to ask for an evening dress, but it seemed a lot to me, but you burned 12.6 liters per 100 km, if you are making sudden accelerations, you can drop it using more calmly.
08.05.2020 15:13 # 3
volkan_uysal
Too much . My LPG also burns 10 liters of mercury. 2004 307 XT 1.6 110 BG
08.05.2020 15:13 # 4
sercinho
I think there is a maximum of 260 cents when it comes to normal, I think the automatic tool will ultimately have 307 manuals usually burn 220 mercury, there is nothing to wear.
08.05.2020 15:13 # 5
It's a little too much for the auto, but don't expect a drop like that. It drops to a maximum of 25 cents.
08.05.2020 15:13 # 6
[QUOTE = ozi033]
friends do not say so directly. conditions of use, fuel quality, maintenance of the vehicle, etc. are so variable there :)) the vehicle will be straight and can burn 10lt, but we automatically test the fuel in my brother's vehicle. He did not fall below 12 :) Our automatic transmissions increase the fuel of our vehicles. There is not much to do ... If there is a loss in the transmission, the fuel will increase even more ...
1.4 automatic 206s do not fall to 10 lt in general ... Waiting for 307 to fall to 10 lt is probably not true :))))))))
the cecol 2011-04-05 10:33:29
08.05.2020 15:13 # 7
volkan_uysal
Sec. cecoli when i say so i actually said so much in price, according to my car Gülme
I didn't know the car was auto Göz Kırpma
[QUOTE = cecol a] [QUOTE = ozi033]
08.05.2020 15:13 # 8
ozi033
Of course, I used it at very short distances and as a 50-55 speed max even without the opportunity to accelerate. It affects a lot but still, if we look at what was written before, it is still a bit more like. maybe it is also noticed from the brand ... though there is not much in the tuber who has the dealership program.
08.05.2020 15:13 # 9
http://forum.peugeotturkey.com/forum_posts.asp?tıd=9845&kw=&pıd=198505&title=aracnz-kilometrede-ne-kadar-yakyor#198505
I copy exactly from the above address.
307 / 1.6 110 hp Automatic gear maintenance is complete.
Today we just pressed LPG until I said I couldn't buy the full warehouse to try. Then I hit the road and came. I traveled 45 km. Road straight split road did not exceed 90km. I went back in the wood, and came back. According to the road computer, it showed 6.8lt / 100km of gasoline. Until I said I can not shake the tank full and shake again. Result:
4.30 lt lpg. In this case, I consume 9.5lt Lpg for 100km. LPG consumption is 20% more than gasoline per liter, so if we say 7 liters, we had to consume 8.4 liters of LPG.
Of course, this straight road only ramp, etc. If the fuel consumption increases. As I said above, 340km but I can go with a tank LPG (Tank 40lt). When I last did a long way, I did not calculate on lt basis, but it burned 0.25krş. I went with more cruise control at an average constant speed of 90-110. This value is not intercity but intercity Ağlama
I will try it with gasoline at a time as to how much it has burned. Let's see if there is an abnormality. The trip computer looks normal, but the healthiest is found with fulle + path + fulle.
08.05.2020 15:13 # 10
I can't understand why, but our transmissions change the fuel so much.
08.05.2020 15:13 # 11
[QUOTE = cecol of]
No, Master, he has a problem at the moment or I don't understand what. I know the periods it burns normally, but we'll find out why at the weekend. What is the reason, now I will completely disassemble the lpg system and have it reassembled. The cost of this informal LPG business has exceeded 2500 liras to me. Ağlama
08.05.2020 15:13 # 12
mimitt
As with every usage condition, fuel consumption changes in every system, and if your vehicle gives automatic gear malfunction, it does not use 4th gear, it increases to maximum 3, which can cause you to burn more.
I want to give an example.
2001 model 406 sv bva (automatic) 138 hp brc my07 kit goes 540 km with a warehouse
2001 model 406 sp manual gearbox is going as 480 km with 138 hp atiker fast. (Same tank capacity of the vehicles)
This test was an experiment we did last summer while two vehicles were going on holiday, we traveled at the same speed on the same road.
08.05.2020 15:13 # 13
insomnia
it is not related to the subject, but let me admit I did not calculate pug liter or km or penny, but until it warms up, 1 colander burns petrol, I do not want to calculate km cents without going to the stress test.
