LPG Engine oil
08.05.2020 14:14 # 1
trigger
Hello friends. On LPG vehicles, should an engine oil produced for gasoline or oil produced for LPG vehicles be used. There is an oil produced by Castrol for LPG and its price is around 3 lt 25 TL. it sounded a little cheap.
08.05.2020 14:14 # 2
trigger
http://www.opet.com.tr/opet-oil/products2.aspx?cat=2&up_cat=217&sub_cat=222&id=250
08.05.2020 14:14 # 3
TOLGA
I use castrol, I throw a boron in 2 oils,
08.05.2020 14:14 # 4
trigger
do you use castrol's lpg
08.05.2020 14:14 # 5
TOLGA
Now I heard from you that the normal 10-40 hyr produces special oil for LPG,
maybe i will try,
08.05.2020 14:14 # 6
trigger
The service here was using the brand Valvoline. I saw it in races, but in real life I saw neither on the shelf nor in the car
08.05.2020 14:14 # 7
fatih1903
Lubricating oils produced for LPG is the same oil choice that only writes for LPG on the label of the oil ....
08.05.2020 14:14 # 8
ali oncu
25 lira was very convenient for me and castrol Ouch
08.05.2020 14:14 # 9
trigger
I did not know the issue of oil. I wonder what to do, he says let's put valvoline in the service.
08.05.2020 14:14 # 10
Onur
castrol cove mobile cove never heard of it I can put valvoline good oil super quality oil coycam if you say petronas cove
