LPG conversion is suitable for 406
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 16:38 # 1
GSli 406
Hi friends,
& nbsp;
I have not been able to raise gas to my car and I want to convert it to lpg even if it doesn't look too hot after the last hikes.
& nbsp;
for lpg conversion I need your brand and master referrals (Istanbul). As far as brand, I heard the master is important. Are you having trouble.
& nbsp;
good markets
08.05.2020 16:38 # 2
I saw a 406 here (Belgium). The owner had LPI when the vehicle was 40 thousand. At the moment, the vehicle was still traveling like 200 thousand hours. I don't know much about LPG systems. In this way, let me ask this question. It is too expensive or does not have the LPI in Turkey? Reviews
08.05.2020 16:38 # 3
GSli 406
As of yesterday, I got the LPG branded system LPG as of yesterday. It is working like a clock for now (it is only 1 day). I will share my satisfaction or dissatisfaction with you in the future.
08.05.2020 16:38 # 4
monur
[QUOTE = koliva]
I've seen a 406 here (Belgium). The owner had LPI when the vehicle was 40 thousand. At the moment, the vehicle was still traveling like 200 thousand hours. I don't know much about LPG systems. In this way, let me ask this question. Is or Is expensive too no LPI in Turkey? Reviews [/ QUOTE]
Reviews
LP and has only scarce difference that differences also used in isolation as far as I know the LPG system. Gas transportation system in LPG While copper pipes are made, LPI uses a different system, and this process is carried out with a pressurized plastic insulated material that is resistant to 345 bar pressure, and transferred to the engine with a spray system. The system they use to convert gas from liquid to gas is very different. Otherwise, the fuel burned is the same Liquid Petroleum Gas .. & nbsp;
08.05.2020 16:38 # 5
[QUOTE = monur]
As far as I know LPI and LPG system, there is only KIT difference, that is, the difference used in isolation. Gas transportation system in LPG While copper pipes are made, LPI uses a different system, and this process is carried out with a pressurized plastic insulated material that is resistant to 345 bar pressure, and transferred to the engine with a spray system. The system they use to convert gas from liquid to gas is very different. Otherwise, the fuel burned is the same Liquid Petroleum Gas .. & nbsp;
So can we say it is a much better system? Are you aware of how much this fee in Turkey? Reviews
08.05.2020 16:38 # 6
monur
[QUOTE = koliva] [QUOTE = monur]
As far as I know, LPI and LPG system has only KIT difference, that is, the difference used in isolation. Gas transportation system in LPG While copper pipes are made, LPI uses a different system, and this process is carried out with a pressurized plastic insulated material that is resistant to 345 bar pressure, and transferred to the engine with a spray system. The system they use to convert gas from liquid to gas is very different. Otherwise, the fuel burned is the same Liquid Petroleum Gas .. & nbsp;
So can we say it is a much better system? Do you have information on how the fee in its Turkey? Reviews [/ QUOTE]
Reviews
I'm the olmadım.tahm witness implemented in Turkey this system VW FSI engines, Peugeot 308 s to this must be the system applied. Their logic is incredibly different. While LPG is delivered to the combustion chambers in liquid evaporation, LPI is sprayed directly as a liquid.
08.05.2020 16:38 # 7
[QUOTE = is MON] Reviews
I'm olmadım.tahm witnessed the implementation of this system in Turkey VW FSI engines, applied to have that in the 308 s system. Their logic is incredibly different. While LPG is delivered to the combustion chambers in liquid evaporation, LPI is sprayed directly as liquid.
I saw this system in an Opel Vectra 2.2 in the Netherlands.
[ / QUOTE]
Thank you. This is a very common system here. However, the number of vehicles with LPG + LPI is very low. But I think you'll see very sought-after, like in Turkey in the next year. As far as I know, it takes 2500 Euro and 4 days to install. Reviews
08.05.2020 16:38 # 8
monur
2500 EUR rakam.y would see a more up very much in demand for Turkey LPI system in terms of security sanmıyorum.fakat gasoline or diesel at least as safe and healthy. Also this is the price Netherlands Turkey prices & nbsp; X3 I think would be " & nbsp; & nbsp;
