lpg conversion
08.05.2020 21:01 # 1
Turcann
I have 2009 1.4 generation 206 vehicles. I bought it 3 months ago. I want to get lpg.
1-Is there any LPG master you can recommend in Adana
2-In the city traffic, the temperature sometimes reaches 110 ° without making too many roads, but it stops at 100 ° on the incoming. It stands between 80 ° and 85 ° on the long road (the vehicle has an open air filter). Is there a solution for this?
I am waiting for your valuable comments. Thank you to everyone in advance
08.05.2020 21:01 # 2
teacher, your temperature is normal in my 206 vehicles, I did not have any problems, just because the radiator hoses worn out, we blew the hose and burned the gasket. Apart from that, I have not experienced situations such as oil reduction or water reduction. your engine should be 1.4 8v 75 bg. The open air filter has nothing to do with the heat of our vehicles. My advice is to find a good lpg master who knows these tools. LPG brands I can recommend
1-lavato obd2
2-atiker obd2
I do not say 3-brc, the old quality is not
4-prins ecomax.
08.05.2020 21:01 # 3
Turcann
I had atiker brand lpg kit.4 I am glad to talk for daily use.In the meantime, I have not had the chance to calculate the fuel consumption. It shifts into reverse in 3 attempts. What is the reason for this?
08.05.2020 21:01 # 4
Karacocuk24
[QUOTE = Turcann] I have fitted an ATIKER brand LPG kit.4 I am glad to talk for daily use. Meanwhile, I have not had the chance to calculate the fuel consumption. If I was more curious, my writer was again. I had a last problem. I don't have much technical knowledge about the reason for at least 2 or 3 attempts. What is the reason for this?
08.05.2020 21:01 # 5
Selcuk55
If you are not going to get into the car for 10 years, the brother who is at the risk of burning LPG does not have a good system under 3000 liras this day. If it does not pass, it is doing it because of wear, pressure, flywheel, gear set. Wink I always say LPG is not a saving factor. You will buy diesel for saving.
08.05.2020 21:01 # 6
Turcann
I dont pay 1800 TL atiker.normally it pays for 10 thousand km.If you calculate the damage you gave as you said, let's get 30 thousand kilometers.I think I will ride for at least 5 years :)
08.05.2020 21:01 # 7
HasGur
[QUOTE = Turcann] I dont pay 1800 TL. It normally pays for 10 thousand km.If you calculate the damage you have done as you said, let's get 30 thousand kilometers. I think I will ride for at least 5 years.
Price difference between B enzyme and LPG There has been no logical explanation for continuing to use gasoline while it has reached its highest value in the last 18 years .
08.05.2020 21:01 # 8
x571
You have done the most logical job. Which vehicle goes 500 km for 100 TL. I have been using it for 6 years, there is no problem. Even once, the arisa light did not come on. Let me take the lpg money out of the car for free. 2500 TL profit in 10 thousand km.
08.05.2020 21:01 # 9
Karacocuk24
[QUOTE = Turcann] I pay 1800 TL atiker.Normally it pays for 10 thousand km.If you calculate the damage you have done as you said, let's get 30 thousand kilometers.I think I'll ride at least 5 years. At this time you have done the right move, it is not wise to ride on gasoline Karacocuk24 2018-09-25 20:30:19
