Lpg care?
08.05.2020 18:18 # 1
Turgay_66
friends, oil, oil filter, lpg maintenance will be done tomorrow, what oil should I use, what should change in lpg maintenance?
08.05.2020 18:18 # 2
elestern
I will be following for the result I will have this month
08.05.2020 18:18 # 3
sosyete_60
Use Mobil or Castrol 5-40 Fully Synthetic Oil, you should put it on the board and use the originals of the oil filters and gas filters. Check the gearbox oil.
08.05.2020 18:18 # 4
C@GL@R
Replace the lpg filter and also the lpg hoses are getting old, especially the heating hoses :) Replace the bidet plastics with aluminum, I think ... why do they still make them plastic?
08.05.2020 18:18 # 5
muhammed.ceyhan
They recommend 10w40 to lpg cars. Does it reduce much oil at 5w30.
08.05.2020 18:18 # 6
sosyete_60
5-40 oil is a fully synthetic oil. I use it 8.000 km in reduction, 250 gr and so on, it decreases to me.
08.05.2020 18:18 # 7
slhyldz
[QUOTE = C @ GL @ R] Replace the LPG filter and also the LPG hoses are getting older times especially heating hoses :) I think the bids are plastic with aluminum. I don't think why they still make them plastic.
You mentioned a very correct subject. There are plastic "t" s in my vehicle exploded after about 50 000 km and I was stuck. But I would burn the engine of the vehicle. I realized it in time and saved it only with subopes. They are something of 5-10 TL and they do not withstand high pressure and temperature and wear out over time. If you explode and overheat your vehicle, you can burn the gaskets and you may have the engine.
A second issue is known, our peugeots don't like the tube. For this reason, I recommend that you have your vehicle fitted with around 100 rubles of sub-lubricants. It lubricates the subops at 3000 rpm and above. Increases subop life. There are two types of it, tubers give information.
Finally, whatever you do, take it to peugeot masters. Only what happens to people can understand what I mean.
08.05.2020 18:18 # 8
Turgay_66
friends changed the oil today castrol 10w 40 drained oil but still took 3 liters? I changed the lpgnin filter, we had a problem there, it was pretending that there was no LPG in the vehicle when it was inserted into the hose while installing the filter.
08.05.2020 18:18 # 9
muhammed.ceyhan
Should it take 3.5?
08.05.2020 18:18 # 10
Serkan
Gasoline gets 3.2 lt, diesel gets 3.8 lt. Probably after using it a little bit you will see the lack of that 0.2 lt
08.05.2020 18:18 # 11
sosyete_60
I wish you used 5-40
08.05.2020 18:18 # 12
Turgay_66
[QUOTE = sosyete_60] I wish you used 5-40 [/ QUOTE] why, hodja?
08.05.2020 18:18 # 13
murat222
So how useful are these boron oil additives? Is it true that I heard it blocked the oil channels?
08.05.2020 18:18 # 14
sosyete_60
it is true that it obstructs the oil ducts but the fake products are occurring :) If you pay attention to buy the original product, you will see your benefits when you use it, it will also be 5-40 or fully synthetic or thin.
