lpg brain change
16.06.2021 21:20 # 1
x571
I'm having trouble with the
lpg brain. I ordered the parts, I will replace it myself. I got the team as https://www.lpgyedekparca.com/atiker-sirali- I turned off regulatoru
I turned off the LPG from the fuse, there is no such thing as a closed valve with a cover, under the tank, bagel, tank and vehicle. How can I do this in the videos mentioned without cutting the LPG ?
18.06.2021 14:27 # 2
talip206
Sir, there is no need to cut the gas in the sequential system. There is already a gas cut-off electronic relay in the tank. Gas does not flow as long as the ignition is closed.
When first disassembling, some gas comes out of the pipes. Carefully loosen it slowly. It is enough that there is no fire around, there is no one passing by with a cigarette in their hand.
18.06.2021 22:48 # 3
x571
thanks. Logically, I thought so. He doesn't have many videos. I thought I'd consult..
19.06.2021 14:13 # 4
x571
I couldn't remove the
water hoses. What did he do with the effect of 9 years? help awaited.
20.06.2021 23:46 # 5
talip206
Oh, isn't there that water hose? I was on the verge of giving up while I was removing it. It takes some force to use. Flip it out. When you turn a little, the rest will be easier.
25.06.2021 17:22 # 6
x571
It also works well to heat water in the kettle and pour boiling water.
