lpg audible warning meaning
08.05.2020 15:53 # 1
tilbe307
Friends, something interesting happened the other day. lpg was in the vehicle. I run my car passed lpg. After a short period of time, unlike the normal lpg ending voice alert, the vehicle quickly gave out an audible warning and exited from the lpg. and then I switched back to lpg with my hand. there was no problem. But what was the meaning of that fast sound alert? Is there anything that happened to you?
08.05.2020 15:53 # 2
It was a malfunction. Maybe there was a momentary problem in the pressure sensor vs there was no problem when trying again.
Gas discharge warning and failure warning are different. If the time is set by the ECU, it can come in a warning that requires you to go for maintenance when the time comes. oter constantly when the contact is closed ...
08.05.2020 15:53 # 3
tilbe307
cecoli and lpg filters should be replaced in a long time. How can I find out which version of my lpg waste is useful?
tilbe307 2011-07-26 14:06:40
08.05.2020 15:53 # 4
My brother, this information is constant, the same in every system. A periodic maintenance is carried out at 10,000 km and the warranty of the system is wetted and the guarantee is activated. If you do it with the oil of the vehicle, you will not forget and regular maintenance will be seen. If you use it, you will get efficiency from lpg.
In addition, the filter does not only change in periodic maintenance. basically if you look as a procedure
work control
pans control
hose control
filter change
setting control
It is a cable related to the lpg system, it is a socket etc. All kinds of parts are checked. over time, the water hoses may harden. needs to be replaced. injector cleaning is done according to the place etc. etc
The bottom of the vehicle should be checked, maybe you swept it somewhere, you damaged the grizzle, etc.
this is the main maintenance
08.05.2020 15:53 # 5
tilbe307
thank you for the information you provided
08.05.2020 15:53 # 6
You're welcome. who cares for me as I mentioned above, but it is also a mystery Sırıtma
08.05.2020 15:53 # 7
metin
I thought it was just a filter change adjustment control thanks cem abi.
08.05.2020 15:53 # 8
[QUOTE = text] I just thought the filter change setting check was thanks cem abi. [/ QUOTE]
Generally, it is so. But essentially, if you think about it, it should be done as I say.
musal water hose will explode hardened, who will know ??? If it is checked, it changes if it is understandably hardened. If the axle explodes in an unusual place, you will be on the road ...
He used a different sample vehicle print and swept gold, the pipe was damaged. If checked, it will be noticed and done as required.
the sockets are rust after 3 days, the voltage does not pass, the lpg valve will not hurt, then it will be found in between Göz Kırpma
these are mythical ...
