LPG assembly recommended
08.05.2020 17:30 # 1
tankut67
Hello friends. I decided to have my model 307 sw premium car lpg now cut because it cuts a knife bone. They said that your head is very painful. But I look at the forums and the companies that make LPG conversion. All of them say we get very good results. .Respects..
08.05.2020 17:30 # 2
Serkan
Hodja, one of the biggest problems you will experience will be the gas gauge drop, the vehicle will drop on the fuel gauge while the car is going to lpg. but then the indicator starts to fake as if you are using gasoline again, if the car runs with little gas continuously, the risk of burning the gas pump increases over time.
To avoid these troubles, make sure to install the PSA module while the lpg assembly is being made, the PSA module will reset the float every time the vehicle starts to show the actual gasoline level in the tank.
Serco05 2013-04-09 16:18:36
08.05.2020 17:30 # 3
impact
[QUOTE = Serco05] My teacher will be one of the biggest problems you will experience is the gas gauge drop, you will not know how much gas is in the tank when the car is going to lpg. When the gasoline is bought over, it shows the actual gasoline, but then the indicator starts to faint as if you are using gasoline again, and if the car runs continuously with less gasoline, the risk of burning the gas pump increases over time.
I have a landirenzo +1, I have been using it for 10 months, electronic, etc. I had no problems. I do not have a PSA module, so gasoline always appears at 0. I would recommend LPG environmentally friendly fuel LOLLOL
08.05.2020 17:30 # 4
elsoberano
I recommend scarce mtm, we used it in a vehicle before, I am using it in 307 right now, I did not have any problems
08.05.2020 17:30 # 5
comolokko
There are 407 premium 2.0 triptonics. 14,000 km has gone I had no problems with my atiker lpg kit.I had no problem with my faulty light or something.I had problems with friends wearing expensive kit (malfunction light is on, low on traction). I said. I am very happy with the opposite. If you search for Google to drop the gas, you can handle 2 liras. You are connecting the resistance and the button is so.
08.05.2020 17:30 # 6
tankut67
I will consider your advice ... Thanks for informing ...
