Lpg and Vehicle brain (can happen to you)
08.05.2020 16:53 # 1
okan4037
My friends tool 1.6 cc & nbsp; 307 .. atiker fast system when i bought ... & nbsp;
Malfunction lamp always lit rare (antipollution fault)
For the first time 6 months ago (catality converter fault) & nbsp; lit the malfunction lamp, there was a strangeness in the vehicle, it fell from the traction started to vibrate) It became unbearable after 2 days and it was closed to service ..
No malfunction found first & nbsp; they suspected the coil or something or the last problem & nbsp; VEHICLE BRAIN 2 injectors & nbsp; & nbsp; (2nd and 3rd number injectors) & nbsp; the brain changed because of not sending the signal ...
6 months later last week again the same catality converter fault and when I hit the gas the car trembled, I immediately switched to gasoline and it recovered & nbsp; I think I saved this time ...
& nbsp; What do you think could be the problem? If the vehicle's malfunction lamp remains lit for a long time, its brain interferes and if I try to continue at LPG as the same malfunction will arise.
I am conducting logic. I do not know Reviews
08.05.2020 16:53 # 2
hakan38
teacher lgp's brain or vehicle brain, lgp have the same problem
08.05.2020 16:53 # 3
okan4037
The vehicle is disrupting your brain
08.05.2020 16:53 # 4
ttaylanaa
Well, I have a thousand regrets that I got lpg. I also have 307. I had the malfunctions you said. I have been dealing with poor mix failure for a very long time. Another failure that Lpgn constantly gives is the coil failure. injectors.
0p171 I have been dealing with poor mixture failure for more than 1 month, finally I solved it and I am not getting that fault anymore. But there are still smaller problems in my vehicle.
& nbsp;
Unconscious work while working in the morning and small jolts when idling when the car is too cold or too hot.
& nbsp; < / div>
As a result, the lpg system added to the vehicle afterwards is not a good choice. Although it seems to be making a profit from fuel, on the other hand it gets more back ...
08.05.2020 16:53 # 5
okan4037
you really wrote such a conscious answer that & nbsp; I agree with every letter of what you say .. especially the hard work in the morning when it lifts the vehicle, it drops a bit of traction, it provides a bit of economy, but it gets back from health and the cost and motor life ..
08.05.2020 16:53 # 6
istanbullu_3886
friends, I use a diesel vehicle, as far as I know, when the lpg brain and the engine brain do not adapt to each other, such situations are frequently encountered, so I think it is more accurate to research and install the lpg brand recommended by the vehicle manufacturers.
08.05.2020 16:53 # 7
ttaylanaa
You should have your vehicle connected to the computer and see which fault it caused. Most likely it is related to the coil. 1-2-3-4. You have received a malfunction such as misfire.
& nbsp;
Lpg gasoline & nbsp; more & nbsp; burn out the coil and spark plugs earlier. The LPG installed in the 4-5 year old vehicle would break the coil in a short time, and if the original coil was not installed, the room would be malfunctioning in a short time. . If the vehicle lights the malfunction lamp, there is a malfunction in the car. If you use the vehicle in that way, you have used the vehicle in a defective way. Believe it - this light comes on, it doesn't matter, you go ahead ... & nbsp; lpg people did not put the malfunctioning piece as a decoration. It will eventually give a solid malfunction to the vehicle that has been used for a long time.
& nbsp;
get past again.
& nbsp;
08.05.2020 16:53 # 8
fince126
Friends, I had the same fault. converter and antipol. error, also shaking and idling vibration, engine diagnostic fault lamp was on steady. Today it was connected to the computer in the industry and gave oxygen sensor failure and excessive burning disorder. sensor changed 170 TL, also spark plugs changed 35 TL, and Z-rods changed 50 TL in pairs, 300 TL in total I love the master. malfunctions have not yet recurred, but it is close, I am waiting again. Unfortunately, I think the fate of these LPGs is 307.
08.05.2020 16:53 # 9
ttaylanaa
[QUOTE = fince126] Guys, I had the same fault. converter and antipol. error, also shaking and idling vibration, engine diagnostic fault lamp was on steady. Today it was connected to the computer in the industry and gave oxygen sensor failure and excessive burning disorder. sensor changed 170 TL, also spark plugs changed 35 TL, and Z-rods changed 50 TL in pairs, 300 TL in total I love the master. malfunctions have not yet recurred, but it is close, I am waiting again. unfortunately, I guess the fate of these LPGs is 307. [/ QUOTE]
Do you remember the malfunction codes? div>
08.05.2020 16:53 # 10
okan4037
[QUOTE = ttaylanaa]
You have to connect your vehicle to the computer and see which fault it caused. Most likely it is related to the coil. 1-2-3-4. You have received a malfunction such as misfire.
& nbsp;
Lpg gasoline & nbsp; more & nbsp; burn out the coil and spark plugs earlier. The LPG installed in the 4-5 year old vehicle would break the coil in a short time, and if the original coil was not installed, the room would be malfunctioning in a short time. . If the vehicle lights the malfunction lamp, there is a malfunction in the car. If you use the vehicle in that way, you have used the vehicle in a defective way. Believe it - this light comes on, it doesn't matter, you go ahead ... & nbsp; lpg people did not put the malfunctioning piece as a decoration. It will eventually give a solid fault to the vehicle that has been used for a long time.
& nbsp;
get past again.
I guess there was something like poverty coming out of a cylinder in the combustion chamber .. when we changed the coil, there was no problem. injectors are not beating the motor brain is not transmitting because of it & nbsp; there is also the possibility that the reason for the lpg taken from the coil may be the confusion in the signals of the cables
08.05.2020 16:53 # 11
okan4037
[QUOTE = ttaylanaa] [QUOTE = fince126] Friends, I had the same fault. converter and antipol. error, also shaking and idling vibration, engine diagnostic fault lamp was on steady. Today it was connected to the computer in the industry and gave oxygen sensor failure and excessive burning disorder. sensor changed 170 TL, also spark plugs changed 35 TL, and Z-rods changed 50 TL in pairs, 300 TL in total I love the master. malfunctions have not yet recurred, but it is close, I am waiting again. unfortunately I think the fate of these LPGs is 307. [/ QUOTE]
Do you remember the fault codes?
& nbsp;
& nbsp; [/ QUOTE]
same malfunction in me, brain has changed, you have changed sensor & nbsp; really interesting & nbsp; & nbsp; I hope the problem is with him .. there is nothing to do & nbsp; I use it in gasoline, we can not spend the money we find on gasoline, I guess, shame on this country.
08.05.2020 16:53 # 12
carantinas
Take a look if you want the catalytic convector to be clogged. & nbsp;
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
