LPG And Gasoline Problem
08.05.2020 14:17 # 1
bodrum7
My friends vehicle was scuba, there was a line of gas in the half tank, around 20 days ago, because of the constant fuel low warning these days, I first bought & nbsp; 5 tl petrol, but the gasoline needle did not rise, immediately after that I bought another 10 tl petrol but there was no movement in the needle again. still gives fuel low warning when I start the car. Could this decrease in petrol in an LPG vehicle within 20-25 days, or did the car not perceive gasoline intake? Because when I bought 10 liters of gasoline, the gasoline needle was coming to its normal place.
08.05.2020 14:17 # 2
hello brother if the lpg sequence system is working on the gasoline at the first start then it goes to the tube automatically then maybe because of this but i still have no clear information
08.05.2020 14:17 # 3
tayfunyesilyurt
As far as I have read from the forum on this subject, the gasoline needle has changed with the way the vehicle's wheel takes on LPG vehicles. In other words, if you fill the tank, while you are traveling with LPG, the gasoline needle drops according to the kilometers. This is my humble comment.
Greetings
08.05.2020 14:17 # 4
vbmaster
I agree, the gasoline needle is not from the float, the problem is not with it, or it will not burn with the first run, let's see what the masters will say ...
08.05.2020 14:17 # 5
serkan.ist
I don't know if the vehicle is a new model and the trip computer is proportional to km & nbsp;. But I do not have such a situation in lpg. I think this is a classic float problem. Sometimes it gets better when the tank is not full.
08.05.2020 14:17 # 6
trtolgi
Hello, my vehicle is lpg li. The same problem has been in me. I bought 10 liras, it is still burning red then 5 liras like you but it is the same again. Then I bought 20 liras.
08.05.2020 14:17 # 7
bodrum7
Thank you for the answers, let's get 20 TL gasoline in the bidet.
08.05.2020 14:17 # 8
bodrum7
Yes, it means that when you buy 20 TL gasoline, the needle has been replaced, at least 20 TL must be bought, it worked well when you received 10 TL but this time it did not happen, it means 20 TL gasoline.
08.05.2020 14:17 # 9
this is happening in newer model pugs. A very normal situation, many 307 owners experience the same situation. the same is true in some 206s. Due to the vehicle's wheel rotation, the gas gauge continues to decline. but the gas stays inside. & nbsp; it is not going anywhere :) it has been discussed so much ...
08.05.2020 14:17 # 10
selcukcivelek
Dear members & nbsp; okay, for the purpose of economy, you had a tube installed, but if the system you are using is a sequential system, the engine of the vehicle will run on gasoline until it warms up, then the LPG transition will happen automatically. & nbsp; storage is messing up & nbsp; 5 & nbsp; & nbsp; In 10 & nbsp; tl gasoline, the vehicle is trying to burn these dirt in time. Problems are revealed in time. I definitely do not recommend satin gasoline prices.
08.05.2020 14:17 # 11
behzat
half a warehouse should always be, I always add it on top, but the pointer always points towards it.
08.05.2020 14:17 # 12
BAHTIYAR
I do exactly that, I always add it to the half tank and when I leave the car on a hill, stop it and start it again, the hand goes down because of the LPG.
08.05.2020 14:17 # 13
[QUOTE = 06BAHO] just like that, I do it all the time, I add it to the half tank and when I leave the car in a slope, stop it and start it again, I went down to lpg because of the lpg, the pointer is getting better, so I went to my sungy sack today, it burned 45 lira lpg at 390km so 15 kurus results made me very happy [/ QUOTE]
& nbsp;
is there anything wrong with the account? If you say 390 km, if you bolt 45 TL, it corresponds to 11.5 courses. According to what you said 15 kurus, you would say 290 km, I thought I thought :)
08.05.2020 14:17 # 14
BAHTIYAR
yes 11.5 cents 390km & nbsp; I wrote it wrong, I saw the wrong from the machine & nbsp; sorry & nbsp; my old vehicle would not fall below 20 cents, these figures are nice 90 100 & nbsp; I went between, I patted the pedal, officially the air conditioner was fully open.
08.05.2020 14:17 # 15
muhlisoz
yau, I started a 300 km road with my car recently, I went without pulling my feet out of gas, burned a full 86 lira of gasoline, if I put gas on me, my napsam started to be expensive.
08.05.2020 14:17 # 16
ali oncu
390 is really amazing with 45 lira. 11.5 is very good. meant it would burn 10 cents if it was closed in the air conditioner
08.05.2020 14:17 # 17
bodrum7
Yes, or your vehicle that burned very well mine burns 21-22 km.
08.05.2020 14:17 # 18
[QUOTE = 06BAHO]
yes 11.5 cents 390km & nbsp; I wrote it wrong, I saw the wrong from the machine & nbsp; sorry & nbsp; my old vehicle would not fall below 20 cents, these figures are nice 90 100 & nbsp; I went between stroking the pedal officially the air conditioner was fully open
& nbsp; < / DIV>
Let me just go hungry. 11.5 kurus doesn't make any sense to me. Because if we calculate the LPG from 1.94, it corresponds to 5.9 lt per 100 km. If you go with your gas, it is only 6 liters per 100 km, but besides the dusers. & nbsp; lpg has to be retained. I think it is not possible with LPG ... when the air conditioner is fully open, I think it's crazy :) I think there is something wrong. but I'm not claiming.
cecoli 2010-06-20 22:00:44
08.05.2020 14:17 # 19
BAHTIYAR
lpg 1. I bought it at the entrance of Ankara in the evening, took 44.96 lira km counter 389 of the gas I bought the gas from Ankara opet 1.78 liters 06BAHO 2010-06-22 11:22:39
08.05.2020 14:17 # 20
BAHTIYAR
I will go to Antalya tomorrow, I will say about 700km of measurements, but it turns out wrong because I got off in the evening because I am going to set off in the city for 200 km 46lra lpg 23 kurus (I use the series in red) & nbsp; I can not enter the net for a long time. edited> 06BAHO 2010-06-22 22:36:57
Page : / 2
