LPG also works
08.05.2020 15:43 # 1
naksi
I have 307 vehicles installed in 2004 landi renzo. The car sometimes does not start when I press the ignition. he leaves me in strange places at all times, a special service put me on the computer i think com2000 could not find his own program
08.05.2020 15:43 # 2
naksi
I guess nobody encountered such a problem
08.05.2020 15:43 # 3
volkan_uysal
Oh my teacher, keep it like this with no play settings :)
08.05.2020 15:43 # 4
Could there be a problem with the gas pump roller ??? I thought it was occasionally not working ...
08.05.2020 15:43 # 5
naksi
would the gas pump relay do this?
there is another detail like this
I got into the car, I hit the ignition, it didn't work
Then, when lpg regulator from the battery gives power to the cable, it does not get it again, it does not work immediately, and sometimes it works. and I leave it in the anthem (of course, two people do it as a driver) then, without pulling the cable, that is, it works normally without pressing any contact without saying anything.
I am tired of changing the place here in the services that have a suggestion and not solving the problem. Somebody who knows you're gonna behave accordingly.
08.05.2020 15:43 # 6
sercinho
Good night, your friend's gas pump was burned, your problem was the same as the problem.
08.05.2020 15:43 # 7
cash1912
I am trying to say that it is not working, I do not come, I do not say it does not work, but there is no fuel, sometimes it does not work.
08.05.2020 15:43 # 8
allah allah..is awkward. i was so curious now..what is still not clear after all ???
08.05.2020 15:43 # 9
naksi
No, it's still not clear
When the vehicle starts and goes to the master, no problem can be found and the master does not cause the problem :)
08.05.2020 15:43 # 10
naksi
Do you have friends with an idea ..
08.05.2020 15:43 # 11
berk2309
Are you sure of the pump? Have you looked at the pump if there is no gasoline in the pump?
08.05.2020 15:43 # 12
ALX
Possibilities in order: Gas pump relay, gas pump, LPG setting. It happened to me once, the pump relay was on fire. My master came, we picked up the lamp, the pump worked, but the starter was not working at pressure. It changed when the relay changed, 70TL relay. If you have a problem with the pump, you cannot get away with 70TL.
08.05.2020 15:43 # 13
tolga.onal
I am going to hose down the issue, but now I am facing this problem, yesterday evening, the gas was over, because the car was already hot, I started working on LPG and went on the road. I bought downhill gasoline when the vehicle was in the compressor, but it did not eat gas, but it still does not work on the gas, I am waiting for your help if there are friends who have the necessary experience.
08.05.2020 15:43 # 14
menajer
The float can cause problems. There may not be enough gasoline. When LPG runs, since it draws gasoline, then it runs on gasoline.
08.05.2020 15:43 # 15
canermusic
There is no solution to this problem, and this is a chronic problem for Peugeot. I am having the same problem with my 206 vehicles now. When the car waits too long or does not run in the mornings, it runs on LPG. Mars prints very well, it has nothing to do with the gas pump because I just changed it, it doesn't show any malfunction, I'm going to the lpg setting. When the car is hot, it works just fine, but when it waits, it doesn't work on gasoline. Are there any friends who have experienced this problem?
08.05.2020 15:43 # 16
talip206
[QUOTE = canermusic] There is no solution to this problem, and this is a chronic problem for Peugeot. I am having the same problem with my 206 vehicles now. When the car waits too long or does not run in the mornings, it runs on LPG. Mars prints very well, it has nothing to do with the gas pump because I just changed it, it doesn't show any malfunction, I'm going to the lpg setting. When the car is hot, it works just fine, but when it waits, it doesn't work on gasoline. Are there any friends who have experienced this problem? [/ QUOTE]
Although the pump is running, there may be a problem like this. The trouble that occurs in the socket attached to the pump can cause no contact. But this socket is not the outer one, but the inner one. In other words, when the seat is lifted, it is necessary to remove the part with the pump. Socket left in the tank. I had to replace the working petrol pump because of it.
08.05.2020 15:43 # 17
ersinyildiz
Sir, I overcame these problems by keeping the gas on half a tank, if you want a try. If you have little gasoline, it can do that.
08.05.2020 15:43 # 18
MURAT32
This problem happened a year ago and recovered after 15-20 days. It started again a month ago. he did not work in the first run, he did not eat cranks down 4-4 times When the engine switched to gas, it was running smoothly. the long road gasoline will improve, said the masters. We went with 300 km gasoline, it did not improve. sometimes the dirt on the gas would interrupt the income, it was happening while it was riding on the gas, sometimes it was stating spontaneously while standing at the lights in the city. There is nothing we hit 150-160 on the way between cities. so we never doubted the gas pump. I thought that sometimes my father uses the vehicle just because my father is using it and he is deaf from him. They said that the injector cleaner will recover, nothing has changed. When we did not work last, we took the way of a master on the recommendation in another city in the morning. The master immediately said the pump, of course, this is not the first master. because in general the masters make different comments. We have now understood that the reason for falling from the traction seen in the city at low speeds, sometimes not working in the morning, cutting gas like stepping on the fire when going, and saying that it is not so good in LPG is the reason for the 90TL pump itself. Most engine masters have LPG brains, LPG adjustment, pipe leaks, filter is clogged, LPG has been for a very long time, we cannot measure the pressure of the pump, we trust the master on many desperate ideas and say goodbye to our vehicle that has returned to its former performance.
to give ideas to those who have similar problems in the purpose. As with every job, if it is not necessary, our time and cash loss industry is cave. my writing was long but I hope it will be useful. The masters who mislead us by saying that the vehicle is a lpg-sourced problem, and despite the fact that the problem occurred 1 year ago, it was misleading that it was spontaneously terminated within 15 days.
The vehicle is 60000km with a tube now at 120.000km at 1.4 xr 307
16.03.2024 21:30 # 19
erhan cay
Hello everyone, my car is 2006 Partner, it has a problem with starting with gasoline. It says it won't start in the morning no matter what I do, the tank pump is new, the injectors are new, the coil is new, the throttle body is new, it doesn't say anything else, when I switch to the gas cylinder, the monster gas goes in the cylinder as it should, I can't solve the problem. Friends who have experienced this issue, please help me, by the way, the gas pump relay is good, the injector log is good, urgent help.
