Lpg advice for 307 2006 sw
08.05.2020 15:13 # 1
oguzcan
Friends 1 week ago I bought 2006 307 sw lpg. What would you recommend? thanks
08.05.2020 15:13 # 2
kaan__
ankara mountain cey lpg transformation center 2004 sw was installed in my vehicle i am very pleased I want to say that a bagel tank was installed instead of steel and a steel protection was made.
08.05.2020 15:13 # 3
oguzcan
thanks
08.05.2020 15:13 # 4
I wish the best...
Any brand vehicle with which you can find a good master will work very well with your vehicle. Because your engine works with full-rank spraying, I don't think there will be any problems when properly assembled ...
Also, do not forget to make obd connection and promotion if you are installing a kit with a fast connection such as waste fast safe obd. more precisely, try to find a place that knows it. then you will use the property of that scarce ... the same situation is available in brands such as zavoli, lovato, lden renzo, brc ...
08.05.2020 15:13 # 5
mimitt
I have a system auto gas and engineering in 88 auto industry sites in Ankara. If you find Onur Ahi, it will help you.
08.05.2020 15:13 # 6
At this point, our brother, mimit, is widespread in Ankara.
08.05.2020 15:13 # 7
oguzcan
Good for [QUOTE = cecoli] ...
Thanks for my master information
This job will cost me a little bit
Because I want the tank out to the bottom room + a cost
08.05.2020 15:13 # 8
oguzcan
[QUOTE = mimitt] I have system auto gas and engineering in 88 auto industry sites in Ankara. If you find Onur Ahi, it will help you, it is as important as the system, in workmanship. [/ QUOTE]
I asked the master of honor today, lovato had no project, but he said 1650 for brc
08.05.2020 15:13 # 9
106_arts
What does obd link do?
08.05.2020 15:13 # 10
As you can understand from the name of the obd connection, it connects to the obd cables of the vehicle and writes to get the information in gasoline's pharmacy. Depending on the situation, the lambda sensor connection may be required or not at the same time. I can not talk precisely because this situation may differ from brand to brand.
At this point, the LPG drug has the ability to change the carbration at certain rates using the data of the vehicle. If these connections and I know it can be done properly, a much more stable lpg system can be obtained ... many masters do not know this system very much.
The brother of the text was also installed in the vehicle of the waste safe fast obd kit but these obd and lambda connections were not made. When I contacted Konya, necessary connections and promotions were made ...
08.05.2020 15:13 # 11
oguzcan
Celoci master told me about a tool of a master brc today. For obd connection.
Not much of the gas gauge before it is installed
08.05.2020 15:13 # 12
MemoTech
Did they say PSA Module?
08.05.2020 15:13 # 13
oguzcan
[QUOTE = MemoTech] Did they say PSA Module? [/ QUOTE]
I'm not sure exactly it was a box up matchbox
08.05.2020 15:13 # 14
mimitt
[QUOTE = oguzcan] [QUOTE = mimitt] I have system auto gas and engineering in 88 auto industry sites in Ankara, if you find Onur Ahi, this is as important as the system, in workmanship. [/ QUOTE]
Did Honor Brother offer you a system? If he suggested, he mentioned a system that would fit perfectly and would not hurt his head. He is a competent person,
If you call again, say hello Mehmet, say hello, let us give you a price like a man :) You can even negotiate face to face. Since he does not like to deal with the fault himself, he installs the most suitable systems, he does not do it even if you give the others two times.
08.05.2020 15:13 # 15
oguzcan
[QUOTE = mimitt] [QUOTE = oguzcan] [QUOTE = mimitt] I have system auto gas and engineering in 88 auto industry sites in Ankara.
Thank you, let me meet face-to-face, this time they also gave the waste to the protected sub-system in 1650.
08.05.2020 15:13 # 16
mimitt
it will help, but if he insists on something, know that he knows.
08.05.2020 15:13 # 17
MemoTech
[QUOTE = oguzcan] [QUOTE = MemoTech] Did they say PSA Module? [/ QUOTE]
I'm not quite sure it was a box up matchbox [/ QUOTE]
Now I recommend you to read it for a long time instead of briefly explaining it.
In the link below, there is detailed information about the connection of PSA Module.
Our friend " cecoli " is a friend who has a better command of these issues. He can give you some useful advice.
08.05.2020 15:13 # 18
oguzcan
Hodja now I understand but can we bind it or is it already in scarce?
08.05.2020 15:13 # 19
MemoTech
For paying the fee and purchasing the place that will make your LPG assembly. But it's not a product that comes out of the kit. A product that BRC also sells. They are assembling themselves.
