LPG
08.05.2020 18:19 # 1
ysndrsn
Hello friends. My car 2006 model 1.4 fever automatic gear 206.aracima lpg tactic was three months. However, on intercity roads, the vehicle is kicking at normal speed, over 100 km. This misfire is like sudden braking, and the car is a continuous pile. There is absolutely no such problem with Benx. The problem ends when you take the gasoline. Master spark plug spark plug cable makes the coil change without igniting. All changed 15 days ago. Filters have changed. The gas setting was reconstructed. The problem still persists. Can you help before going to the master. The problem was not in the gas system, but I think the problem is in the gas. Thank you for helping
08.05.2020 18:19 # 2
ysndrsn
The vehicle has the energy-by-product mind kit friends
08.05.2020 18:19 # 3
Serkan
The best way to escape from the LPG masters is to say that there is no problem in LPG.
08.05.2020 18:19 # 4
ysndrsn
No one can help?
08.05.2020 18:19 # 5
rolandgarros
If the problem is in gas, please tell the master that he is not doing it in gasoline, and give him the opportunity to test and get out hard. I think if the tube is just installed, they should solve the problem.
08.05.2020 18:19 # 6
muhammed.ceyhan
definitely the problem is about lpg. If there is another problem, it will do in gas.
