lowering torsion
08.05.2020 15:03 # 1
by-cx
friends, I just bought my slm vehicle, the back of the vehicle, like a chick dressed in high heels, I also use pug in the air for the first time. All kinds of cars going. But I am waiting for your torsion master and spring suggestions.
08.05.2020 15:03 # 2
gozem
I have 307 buddy, I cut the bows and hardened them. It was so beautiful as an itchy and it attracts attention everywhere. I am glad but my advice to you is to buy a sports bow instead of taking a nap, the time of inspection will get the original fit. But as a result of the car's pickup, you cannot enter and exit everywhere and use it more carefully.
08.05.2020 15:03 # 3
by-cx
There is a bidet inspection incident, my room is a nuisance. I will drop it a little or do not cause much trouble, I suppose. Is there any friend who is experienced in this business? Ouch
08.05.2020 15:03 # 4
Don't be afraid of the springs. You can take Eibach 3.5cm and drop the back torsion 1 tooth.
08.05.2020 15:03 # 5
muratgulen07
If you do not lower the hood enough to rub it, there is no problem with the visa ... I know that it is harmful to cut it, but.
08.05.2020 15:03 # 6
gozem
The most likely thing to do is not to rub, shock absorbers hit when 4-5 people ride. There is no difference in sports broadcasting with a shortcut.
the same thing if you say it is harmful, BUT,
^^ if you don't wear shock absorber with sport bow ^^
08.05.2020 15:03 # 7
muratgulen07
If they do not rub at full speed, they will not cause problems.
08.05.2020 15:03 # 8
herry
Should I replace the shock absorbers after wearing a sports spring? What problems may arise if not changed?
08.05.2020 15:03 # 9
redlinemst
I am absolutely against cutting and mower heating. You are playing with the structure of iron, this issue underestimates our society, unfortunately. Ermm
If you are crowding sometime, I do not recommend more than 3.5 cm. It fits the original shock absorber more easily and does not cause much trouble and decrease.
Available in many shopping sites. Download 1 tooth or something to a good master in torsion. The torsion job is a bit difficult :)
08.05.2020 15:03 # 10
darkred
I do not recommend lowering the torsion, otherwise you can distort the torsion arm and the seat on the axle. It would be costly. Because of this problem, I had to buy a complete rear axle in the industry.
I wouldn't recommend downloading a little more ...
08.05.2020 15:03 # 11
kabusizmit
Dude go buy a spring, just get the room 3.5 cm. I use 3.5 in 307 im 3.5 if you get the advantages;
1.There is no headache in examination. (I passed the examination)
2. Do not tire the shock absorbers (If you take 5 cm, it will hit the shock absorbers a lot.)
Do not cut the original springs. They heat the spring and deteriorate its strength. Let me tell you what happened to my friend. He cut off the front springs of the 206 rc. After a while it broke, the car threw himself to the left and entered the barriers.
Torsion settings can damage the axle.
08.05.2020 15:03 # 12
redlinemst
[QUOTE = nightmare] Dude go get a bow just get the room 3.5 cm. I use 3.5 in 307 im 3.5 if you get the advantages;
Exactly, I tried to explain these to my teacher
08.05.2020 15:03 # 13
I rob many times. taking a bow is completely dangerous. our masters are ignorant. It's very dangerous. If you look at it as an engineer, such an application should never be done. Changing the hardness of the metal can lead to breakage of the spring, such as an example of a friend. Do not forget such a risk ... do not forget that you go on the top of the springs ...
08.05.2020 15:03 # 14
orhanetap
I do not know much about springs, I do not know what the cm changes
But I know that my car is not good at the bend, do I have something like sports bows without dropping the car
08.05.2020 15:03 # 15
[QUOTE = orhanetap] I do not know much about springs, I do not know what the cm changes.
how are your tires ???
In fact, the 206s are not vehicles that do not go so far ...
08.05.2020 15:03 # 16
by-cx
friends I understood the front 3.5 I will get a spring, also the shock absorbers need to change. Is there a master we can recommend the back torsion event?
08.05.2020 15:03 # 17
d3Li
You do not need to change the shock absorber on the 3.5 spring
08.05.2020 15:03 # 18
by-cx
ok brother bro thank you if you can find a bidet master for my torsion ..
08.05.2020 15:03 # 19
d3Li
I can help if you are in Ankara
08.05.2020 15:03 # 20
by-cx
Istanbul ZEYTINBURNU would be good if it is on the far European side of Ankara. There is no sound from anyone. I will throw 2 bags of cement
Page : / 2
