low traction when the tank is full
08.05.2020 15:46 # 1
ask307
Hi friends, now I am completely convinced, whenever I make a full tank of my vehicle, there is a noticeable low traction in the vehicle.
08.05.2020 15:46 # 2
It was the first time that I thought something like this ..... Confused I am very curious about the result of this job ..
08.05.2020 15:46 # 3
Could it be because the vehicle is getting heavy ?? Sırıtma
08.05.2020 15:46 # 4
berk2309
I wonder if there is a fuel injection in the injector.
08.05.2020 15:46 # 5
Did they accidentally attach a truck tank to your vehicle? Dil Çıkarma
It doesn't matter much in weight. You're sure it's not psychological, right?
08.05.2020 15:46 # 6
[QUOTE = Menderes] Did they accidentally attach a truck tank to your vehicle? Dil Çıkarma
It may be EmbarrassedEmbarrassedSırıtma
08.05.2020 15:46 # 7
ErcaNKarsI
Embarrassed it is not full already, friend :) you will adapt to the time: D You will get a 20 '50 then the evil eye will be like this: D: D EmbarrassedEmbarrassed This is the first time I have heard a joke
08.05.2020 15:46 # 8
[QUOTE = ercankarş of] Embarrassed it is not full already, friend :) you will adapt to the time: D You will get a 20 '50 then the evil eye will be like this: D: D EmbarrassedEmbarrassed This is the first time I have heard of a joke. [/ QUOTE]
Exactly, my friend, itch. SırıtmaEmbarrassed You will not make such mistakes in the middle ... EmbarrassedSırıtma
08.05.2020 15:46 # 9
sercinho
Even if it is past, there is a problem with the fuel pump, and it cannot send the tide at the required pressure.
08.05.2020 15:46 # 10
sercinho may be right, it will make more static pressure in the pump full of pump, which shows negative effect in pumps operating with delta p (pressure difference principle),
Also, just because of the slight slowing down in f1, young people do not do it in seconds, maybe we do not feel like that. Embarrassed
the mustafa_usl 2011-07-06 14:20:21
08.05.2020 15:46 # 11
[QUOTE = mustafa_uslu] sercinho may be right, it makes more static pressure in the full tank pump suction that delta p (working principle with pressure difference) shows this negative effect,
teacher, you enlightened us EmbarrassedEmbarrassed we are already stuck StarSırıtma
Alkış
08.05.2020 15:46 # 12
Embarrassed there was an exaggerated seriousness above Sırıtma
08.05.2020 15:46 # 13
[QUOTE = mustafa_usl of] Embarrassed there was an exaggerated seriousness above Sırıtma [/ QUOTE]
Embarrassed
08.05.2020 15:46 # 14
ask307
Thank you both for your serious comments, now my car is 100000 km, 73000 km zero injector was installed, the diesel pump was repaired, the fault is slowly turning the tension.
08.05.2020 15:46 # 15
Baybars
I think it is because of its weight in fuel when you do not fill your tank.
08.05.2020 15:46 # 16
okan77
You don't need to laugh right what you say :) I have friends who experience this situation especially in 307.But gasoline vehicles
08.05.2020 15:46 # 17
When I get the diesel full, the car accelerates even more. Sırıtma it's a psychological situation. But when you get stuck, look at your mosaic filter, when was the last time you changed it? This is the best one with 20 thousand refresh
respects
